Denon AVR-3800H vs Denon AVR-4800H
The Denon AVR-4800H is the more powerful and feature-rich model, positioned as a step up from the AVR-3800H. Here's a comprehensive comparison:
Power and Amplification
The
AVR-4800H delivers 125 watts per channel (8 ohms, 20Hz-20kHz) compared to the 3800H's
105 watts per channel. More significantly, the 4800H uses a
monolithic amplifier design with each amplifier module on a separate board using higher-quality components, whereas the 3800H uses a shared PCB for multiple channels. This architectural difference can result in better dynamics, improved channel separation, and a cleaner sound from the 4800H.
crutchfield+2
Processing and Audio Features
The
4800H features 32-bit processing (AL32 and HD32 processing), providing greater precision in audio signal processing compared to the 3800H's standard processing. Both receivers support the same immersive audio formats—Dolby Atmos, DTS:X, Auro-3D, IMAX Enhanced, and 360 Reality Audio. The 4800H supports 5.4.4 Dolby Atmos setups specifically.
homecinemachoice+2
Channel Configuration and Subwoofers
The
4800H provides four independent subwoofer channels, while the 3800H supports standard subwoofer connectivity. The 3800H can support 5.x.6 and 7.x.4 layouts, whereas the 4800H is optimized for 7.4.4 configurations. Both offer 9 channels of internal amplification with processing capability up to 11.4 channels.
reddit+3
Video Connectivity
The
4800H has 7 HDMI inputs versus the 3800H's 6 inputs. Both feature HDMI 2.1 with 8K/60Hz and 4K/120Hz support, though the 4800H has a front HDMI port while the 3800H does not.
prohifi+1
Build Quality
The 4800H includes a metal front panel and is manufactured in Japan, offering a more robust build compared to the 3800H.
simplehomecinema+1
Practical Sound Performance
In real-world usage, the acoustic difference may be subtle for casual listening. However, the 4800H's superior amplifier design becomes more noticeable when driving height channels or when demanding clarity and channel separation, particularly if you're sensitive to transient detail and low-frequency dynamics.
reddit+1
Value Proposition
The
3800H offers better value if you plan to use external amplifiers and treat the receiver primarily as a processor. The
4800H delivers superior value if you'll rely on internal amplification, especially for complete speaker configurations that utilize all nine channels. Given that the 4800H inherits the amplifier design from the flagship X6700H, it represents notably better sonic performance than the 3800H if you can justify the price difference.
simplehomecinema
- https://www.crutchfield.com/p_033AVX3800/Denon-AVR-X3800H.html
- https://hometheaterhifi.com/reviews...eceivers/denon-avr-x4800h-av-receiver-review/
- https://simplehomecinema.com/2023/02/06/denon-x3800h-versus-denon-x4800h/
- https://www.homecinemachoice.com/content/denon-avr-x4800h-av-receiver-review
- https://prohifi.in/blogs/news/denon-avr-x3800h-vs-denon-avc-x4800h-a-detailed-comparison
- https://www.whathifi.com/reviews/denon-avc-x3800h
- https://petertyson.co.uk/denon-avc-x4800h-9-4-ch-8k-av-amplifier
- https://audiot.co.uk/p-31038-denon-avc-x3800h-av-receiver-denon-audio-t.aspx
- http://www.sevenoakssoundandvision.co.uk/p-55775-denon-avc-x3800h-av-amplifier.aspx
