Denon PRA-S10 Review (Preamplifier)
Well, if you would be willing to send the unit off to Germany, yours truly has a Levear VP-8193D and some experience measuring tuners with it... (Side note, isn't FM broadcasting gone in Switzerland now? The Säntis frequencies used to carry far inland and I was kind of sad to see them gone from the band here when I revisited FM earlier this year.)
Oh no, why didn’t I publish this way before? Of course I would have sent you one! But like you said, public FM stations have been stopped in CH a year ago.
So I got rid of two of these Denon tuners, sending them to friends in France for a prolonged life.
That is merely a rule of thumb. In practice there is a massive spread depending on how much use the unit has actually seen, what environment it was in and what capacitor quality was like to begin with, plus some sheer pot luck. Parts in always-on circuitry tend to age a lot more that those turned off as well, so units with soft power from the '90s can be more problematic than their older cousins with hard mains-side power switches. (The PRA-S10 belongs to the latter variety, thankfully.)
Possibly a compromise between CMRR and noise, not a very good one mind you. The input unsurprisingly is not AES48 compliant either, although the presence of a 10µ cap between XLR shell and signal grounds indicates an attempt to deal with pin 1 issues. Looks more like high-level bodgery to me than them actually knowing what they're doing. (It is also old-fashioned in that it seems to be pin 3 hot, while pin 2 hot is the accepted standard these days. Pin 3 hot is uncommon post-1990 or so.) If it was my unit, I would want to modify the line receiver resistor values for proper balance and -6 dB at the very least.
Side note, seeing a discrete folded cascode input that actually seems to work well on the main amp is a bit of a surprise. These can be really good in IC form but discrete implementations are often disappointing. Perhaps the choice of a dual JFET for the input is helping matters. Mind you, this amp sees so little common-mode action that it may just as well have used a traditional cascode.
I'd be whacking on some 220µ-470µ/10-16 V caps in parallel to 2.0 V zeners ZD201/202, that should quieten down the current sources (which in turn would hopefully address some of the elevated noise seen when turning down the volume, assuming it isn't actually coming in via the supply rails). Usually when people need low-noise voltage references in this region, an LED would be the more common choice these days, but this trick may not have been very well-known pre-2000s.
Yes, time, temperature & lack of voltage derating will reduce electrolytic life. Internal temperature due high ripple current or external temperature such as being placed next heatsinks etc are equally bad. Contrary to your statement, I believe high inrush currents are problematic too, advice from many is to leave equipment powered on to avoid inrush?
Thank you NTTY for your time and valuable work.
As always, thorough, well-explained, and well-organized!
Thanks to you and indeed! And I must admit I have much more devices than time to review them :eek:;)
I really hate that for you NTTY. ; )
Thanks for the excellent review! Between you and Amir I’ve been getting quite the education. Dear god please don’t let there be a final exam.
Thanks for the insight. :)
May I just make a minor point about the above quote: the 2SK369 used in this Denon is not a dual J-FET. You must have mistakenly read the reference 2SK389.
Interesting question!
To me, this is superb performance. The Japanese amplifies, both pre and power, from that era, might have been the best ever.
Indeed, you're right (as usual). Perhaps they had been hand-matched or at least pre-sorted. Input balance appears to be good.
Had one of these, loved the sound ( here come the measurement nazis) but found I was only using the first bit of volume dial, up to 9 o clock.
Input sensitivity too high for things like cd players I believe.
I commonly find older analog gear is like that. I think there was a perception that stuff was more powerful if you didn’t have to turn the volume up very high and so companies put real aggressive tapers on the volume.
