Example: MARANTZ PM8005I'm guessing that neither the Denon nor the Marantz could handle a "difficult" speaker very well except at modest output levels.
hiThe Marantz and the Denon are very similar in power output, just based on maximum power into 4 ohms I doubt anyone could tell them apart by listening. They are within 1 dB of each other according to their specs.
What is more important is how they handle various speaker loads - low impedance or high impedance phase angle can demand a lot of current from an amplifier and that is where not all amplifiers are equal in performance. Of course, the mfg's never specify performance as regards to low impedances or difficult loads. Some amps do specify maximum current output which can give some idea of how they handle real world loads. Just based on their market positions, I'm guessing that neither the Denon nor the Marantz could handle a "difficult" speaker very well except at modest output levels.
Some speakers are VERY easy to drive and with such speakers either of these amps would be fine. The Devore Gibbon is one such. Polk speakers are usually quite easy to drive. People say that Klipsch horn speakers and JBLs are easy to drive but I've never liked the way they sounded. And "easy to drive" is NOT the same as high efficiency, though efficiency often does come into the picture.
When manufacturers rate output power of amplifiers they drive a signal into a plain old resistor. All a resistor does is take electrical power from the amplifier and turn it into heat. But we don't use amplifiers driving resistors to heat our rooms - we use amplifiers driving SPEAKERS to reproduce music. And a speaker is **NOT** a resistor. A speaker doesn't just take the power from the amplifier at any frequency and turn it into heat. A speaker reacts differently to power from the amplifier at different audio frequencies, and at some frequencies it will sort of "fight back" against the amplifier, becoming more difficult to drive at certain frequencies and so on. It's quite complex, and there are many very fine speakers that are quite difficult to drive. Read some speaker reviews in Stereophile in terms of impedance analysis and you'll get an idea of the differences in speakers in terms of "driveability."
hiHonestly, I can’t say it sounds bad, but when I first got it, I was constantly cranking the treble way up to get it to sound right for me. It took a while, but I started to vibe with its unique style, you know? It’s got its own personality.
Then I switched back to my old TEAC AR600, and whoa, what a difference. Just for kicks, I dug out an ancient PROTON AM-20, thinking it’d be a total letdown compared to the others.
But, man, that little guy surprised me—it actually sounded pretty awesome! I mean, this thing still holds its own, but now I’m wondering if my ears are just playing favorites.
The TEAC AR-600 is an amplifier that pumps out serious power, giving you deep, punchy bass that’s always on point and mids that sound clear and smooth without wearing you out. The highs can get a bit bright at louder volumes, but overall, it creates a huge, lively soundstage. For the Marantz and Cambridge I have not idea how they sound.hi
in my option it doesn't sound bad at all , i guess better than marantz
does TEAC AR600 sound more flat /analog like marantz or a british amp Cambridge or audiolab ?
Fun fact: ALL solid state amps if not overloaded sound the same. Speakers can sound differentThe TEAC AR-600 is an amplifier that pumps out serious power, giving you deep, punchy bass that’s always on point and mids that sound clear and smooth without wearing you out. The highs can get a bit bright at louder volumes, but overall, it creates a huge, lively soundstage. For the Marantz and Cambridge I have not idea how they sound.
thats a fun fact I can agree withFun fact: ALL solid state amps if not overloaded sound the same. Speakers can sound different
Show us the double blind repeatable listening test. I'll wait. And I did say "if not overloaded" so that takes care of your "watts" examplethats a fun fact I can agree with
........................................ ^dis
I can assure you, even my untrained ears from 1975 to today can hear the difference between the cheapest radio shack amp, a JVC amp, a pioneer amp, cambridge audio amp, and fosi amps at different price points. Watts, tone and signal paths all vary.
You are peeing against the wind here when you say things like that in this forumthats a fun fact I can agree with
hiFun fact: ALL solid state amps if not overloaded sound the same. Speakers can sound different
I’d say that they can sound the same, but that is not guaranteed. Differences in noise levels and output impedance can have an audible impact on how the speakers and amplifiers interact. “If not overloaded” encompasses a range of specific variables in power delivery, some of which can be meaningful.Fun fact: ALL solid state amps if not overloaded sound the same. Speakers can sound different
Agree - Room EQ makes a far bigger difference than the minor electrical differences between solid state amplifiers.Stop obsessing about negligible differences between amps and concentrate on the room first and then the speakers. Add some EQ to at least notch out the room modes.
hiAgree - Room EQ makes a far bigger difference than the minor electrical differences between solid state amplifiers.
By overloaded I mean the amp has enough power to drive the speakers at the volume desiredhi
may i ask you what does it mean "overloaded" ?
for an amp means powerful amp?
120Hz and multiple most probaby are from unstabilized power supply for amplifiers. Or more precisely, because of limited power supply noise rejection ratio. 60Hz and multiple maybe because of ground connections.Some of the measurement results show the fundamental frequency of the electrical network (60 Hz) and its several harmonics (120, 180, 240 Hz etc) in the interference level. Would the device testers have any idea where and through what these interference signals come from? Are these due to, for example, poor rectification and filtering of the operating voltage of the amplifier stages, or are these “spikes” due to, for example, interference caused by the magnetic field of a nearby mains transformer? Both are probably quite easy to find and eliminate … if the designer tests his devices properly. But maybe this costs too much?
