Denon PMA-600NE amplifier + Klipsch RP-600M II speakers
prem86
Hi all
Denon PMA-600NE + Klipsch RP-600M II for a 12 m² room.
I mainly listen to rock and metal on CD and vinyl.
Is this a good combination?
Because my room is relatively small, I'm not considering floor-standing speakers, as I believe bookshelf/standmount speakers would be a better match for the available space.
Do you think the Denon PMA-600NE and Klipsch RP-600M II are a good combination for this room size and music preference? Are there any other speakers I should consider in a similar price range?
Thanks in advance! Much appreciate any help.
Wow! I have the exact same combo! Its in an 11 by 12 "listening room". Works for me. I listen to Classical exclusively and mostly solo piano fwiw
Thank you for your answer. How your small room interacts with your combo? What is your speaker placement in the room?
I keep it simple LOL
I'd want a sub with those speakers myself. If you like the speakers, they should work well and as long as the integrated amp has the features and power you want, they're fine in and of themselves. OTOH those speakers have inflated sensitivity spec (typical of Klipsch) and the integrated amp is on the light side power-wise and lacks bass management/eq. Why did you pick that integrated amp particularly?
FWIW Floorstanders take up generally the same floor space (if using stands) but you gain some bass response/efficiency generally.
I mainly listen to rock and metal, so I'm more interested in dynamics, guitar sound and overall clarity than in having massive low-end bass. For that reason, I don't feel a subwoofer is a priority for my listening habits. My room is only 12 m², so I'm not considering floor-standing speakers. It's not really a matter of floor space, but rather my concern that floorstanders may be too much for such a small room. That's why I'm looking at standmount speakers like the RP-600M II.
I chose the Denon PMA-600NE mainly because it fits my budget and seems to be well regarded as an entry-level integrated amplifier. I don't listen at very high volumes, and my room is only about 12 m², so I assumed its power output would be sufficient.
I also feel that the amplifier-to-speaker price ratio is reasonably balanced in this case. In my market, the RP-600M II costs roughly twice as much as the PMA-600NE, which seems quite common advice among audio enthusiasts, where speakers are considered the more important part of the system.
