As usual with this kind of statements, I just want to throw in words of caution.
There are no statistics known to me about the software or hardware tools that were used to produced all of the more than
16,670 SACDs released to this date.
However, production tools have existed—and still do—that allow for at least editing, and sometimes more advanced signal processing, on DSD recordings without needing to convert (or "decimate", to use the technical term) the DSD to PCM at standard sampling rates like 44.1, 88.2, 96 kHz, neither at 192 or 352,8 kHz or the like. Without an exhaustive database of the exact tools and processes used to produce every SACD, one obviously cannot claim that the majority of SACDs originate from PCM masters or were converted to PCM at any stage.
This is particularly true given that the vast majority of released SACDs are classical music recordings. For this type of production—especially recent releases from small labels—signal processing is generally less intensive than for other musical genres.
Andrew Demery, who worked for both Sony and Philips and was part of the team supporting the SACD rollout to music labels, was responsible for maintaining a catalog of all SACDs; he stated on the Steve Hoffman forum
in 2013 that, at the time, most SACDs had been produced using the Sony Sonoma editing system, which does not perform any decimation to PCM. Back then, other DSD production systems were almost all based on the same Sony processors and advanced signal processing cards developed by Sony Oxford (Sony’s professional division)—such as SADiE DSD8, Sonic Solutions DSD.1/DSD.X and Genex Mix+. When Sonoma was taken over by Gus Skinas's Super Audio Center in 2004, he turned to the early Sony mixing cards—still avoiding any DSD-to-PCM decimation—to build editing systems capable of handling up to
32 tracks. The other significant system available was Merging’s Pyramix; while it did feature a mode that converted all DSD recordings to DXD (which is simply a trade name for 24-bit/352.8 kHz PCM) for heavy processing, it also offered a second mode allowing for only editing of DSD recordings without requiring a full conversion of all tracks to DXD. Finally, Pro Tools was also a tool for producing SACD masters, but it converted everything to PCM before re-modulating to DSD.
Today, a new player has entered the professional market:
HQPlayer Pro software. Like the Sonoma and Sony Oxford systems of the past, it can handle DSD input without downsampling it to PCM at a lower sample rate; instead, it can preserve—or even upsample—the DSD signal.
Consequently, the situation is far from simple, and no sweeping generalizations can be made regarding SACD production methods.
The same applies to dynamic compression, which—incidentally and to the best of my knowledge—can only be performed in PCM using Merging Pyramix in DXD mode or Pro Tools, or without a decimation stage in PCM using Sony Oxford dynamic processing cards, but not with very early or very late (i.e., from 2004 onwards) Sonoma systems.
