Bear123
- Joined
- Nov 27, 2019
- Messages
- 796
- Likes
- 1,370
THX reference level does not state that all speakers and subs combined have to be able to hit 105 dB peaks, but rather that each individual speaker could be required to be able to hit clean 105 dB peaks. Also, in your above calculations, are you using the 1m spl based on speaker sensitivity? If so, the above numbers work if you are 1m from the speakers. Otherwise, I'd reduce SPL calculations by 3-4 dB or so for each doubling of distance indoors. At 12 ft in my room, SPL drops about 8 dB from 3ft to 12 ft(distance is doubled twice).Thank you for your input. I agree that I would need less power than what the Crown calculator showed.
According to this chart, I would need 64 Watts to reach THX 105 dB reference level if my speaker has a sensitivity of 87dB@1 Watt.
I'm listening to two speakers in a small/medium room size.
View attachment 128677View attachment 128677
I also think room gain should not be added to these calculators, as I don't think there will be room gain above 1KHz, i.e. the majority of the frequency spectrum.
Also, we should consider that below 500ish Hz, room eq will likely be adding 3-6 dB of boost at minimum, which will negate any potential room gain that we might be getting at lower frequencies.
