Denon AVR-X6800H now released.
Have you tried asking in the massive AVS thread?
Thanks for this link.
Dirac help desk has just send me an email. So I retry with the last version of Dirac software v3.12.2 and still the same issue: noise similar to a crackling in the fourth subwoofer
They will take a look to my dirac project file...
PS: Like you I find clearest dialogue on center channel with Dirac compare to Audyssey. Easy to compare using the both speakers preset.
Hello,
I try to do second Dirac calibration with my X6800. However I have static noise when the measurement sound is emitted on the fourth and last subwoofer. Measurement is done but such noises inevitably have a negative influence on the measurement result. So I stop and I reversed the RCA cables at the power-amp input. Result those noises are change of subwoofer, so the problem come from X6800 when it generate sound measurement for the last sub.
Has anyone experienced this problem before?
Thanks
I can 100% confirm I've noticed this as well. At first I thought it was a defective subwoofer, but I tried it with a different sub from another manufacturer, and the sound was still there. It is only present when running the sweep using Dirac, and only on subwoofer channel 4. It didn't seem to cause noticeable issues with the measurement, as the sound appears to be above normal LFE frequencies and is much lower in volume relative to the sweep, but I definitely hear it standing next to it during the Dirac sweep. It's not there at all under normal listening situations or even when feeding it low frequency sweeps manually (e.g. YouTube, etc).
I suspect it could be something with Dirac, but also wonder if it's related at all to the DAC configuration on the X6800H. The X6800h uses 2 ESS 9017S DACs and 1 TI PCM5102 DAC. The ESS DACs are 8 channels each (16 total), but with the 4 subwoofer channels, the x6800h technically needs 17 DACs (13 channels of processing plus the 4 subwoofers). So for cost reasons (I'm pretty sure), they added a single TI DAC whose duty is entirely just the 4th subwoofer channel.
I'm not saying this is 100% the cause, but it seems like more than just a coincidence.
@DTSman and @BalanBro , there's one more thing you can try.
Folks w/PAC receivers have been hit hard by the DLBM/DLBC "off by 1" error in the latest firmware update. I haven't heard Denons experiencing this but I'm not ruling it out!
One solution from folks in AVS has been to go back to Dirac 3.10 and the error disappears! Yes, it requires calibrating again but worth a shot!
"Overrated is in the eye of the beholder".
I don't like their pricing either but the base Dirac Live license gives us another room correction option (which gave me the clearest dialogue from the center channel compared to Audyssey, MCACC, etc.).
Anthem Room Correction provided clearest dialogue for me. I wish their avr's weren't so expensive.
Not only that, it is also very disappointing that in order to get two discrete subouts one has to go right to the flagship model. Another minor thing is that those who wants to use their desktop DACs, they won't be able to bypass the ADC/DSP/DAC like the D+M users can. As to "expensive", they don't sell anywhere near as the big guys like Sony, Yamaha, Onkyo, D+M so it is understandable that they have to sell at higher prices. They include a very good mic and stand, that I think is worth an extra 100-$120, or $70-$80 over those cheap looking Yamaha, D+M mics. ARC G, unfortunately, while nice that it is included and the UI looks great, is not effective objectively and relatively to DL and Audy-app. That's a pity because they could easily close the gap if they had made the beautiful app less restricted for manual tweaks. To be clear, I mean objectively. Subjectively, ARC G owners would swear by the RC's effectiveness, though obviously anyone can say anything when no supporting measurements are required. Nothing is perfect, overall, if in Canada, I would definitely think Anthem AVRs are highly recommended when they are on sale.
Unless one has a true reference level center and placed it correctly (in at least half decent room, with decent MLP positioning), it is likely that some EQ might be required either to gain clarity or to tame the speaker in the areas you care about. Even for reference setup, EQ will be needed if one has specific preferences.
Comparing the default EQ results from various EQ system might as well be the determining moment for most, and then some might venture into some additional curves to tune to their preferences. How this actually turns out to measure in reality will be difficult to tell without checking with REW what the after-correction result is. And even when one does that the question is what do you do with the results if you can't correlate them to your preferences. The last point requires some really geeky involvement and lots of hours of figuring our what you like or don't like within the limits or acceptable (or not so much so) measurements. And that's only the center speaker. Many have more than that o_O,
The point being - most people use completely different process and criteria to compare different speakers and EQ systems in different rooms. So the empirical results are pretty random and recommendations should be taken with a more than few grains of salt.
@peng has done some actual heavy lifting in this area, so kudos to all the great work in that respect :cool:.
Infinity RC263 followed by Revel C205 solved dialogue intelligibility issues. Although 205 is a 2 way, I prefer over Infinity.
Thanks for the kind words. I just hope we can influence more people so that they wouldn't mind spending around $100-$120 shipped, Umik-1 and REW (free) that would allow them to save a few filters for their DLBC or Adyssey runs that should sound good in different ways based on the measurements that are repeatable. Of course to those who just don't bother finding out what kind of difference they could discern and/or are not really picky on the differences could just run it, leave it and enjoy it.
For those who do care about the potential audible differences and want to choose the one that would work best for them, I just thought they really couldn't achieve much of anything by simply ask others for their subjective opinions, yet we see that on various forums almost every day. I mean questions like "for sound quality, which avr would you recommend, room correction is important to me, but should I go with Audyssey, Dirac, Trinnov, REW/A1, YPAO etc...., or, I keep hearing Anthem ARC is the best, should I just get an Anthem and be done with it...." Then they would receive all kinds of opinions, but then...what do do:D?
Hi all - recent new 6800 owner and member on this forum here. I am using an external amp to drive the 2 front LR speakers and I just bought a Bluesound Node Icon for a streamer. I would like to get some advice from the gurus here on two possible ways to maximize sound quality for both movies and music:
1) Connect Icon via HDMI to 6800, then RCA out to external amp for 2 speakers and speaker wires for surrounds, or
2) Almost run two parallel systems, with 6800 pre-amp rcd to Icon as analog in, and XLR from Icon to external amp. Thinking here is when watching movies, will use the 6800 to decode and Icon just passes the signal through to the amp, and when listening to music, I can keep the 6800 off completely and just stream directly from Icon via XLR to the amp and speakers.
Maybe I'm just overcomplicating things running option 2, and might ultimately come down to which DAC is better between Icon vs the 6800? The only time that option 2 makes sense would be if stereo mode Icon by itself is better than running stereo through the 6800 I'm guessing.
I saw a few comments earlier regarding the DACs, and saw primarily people recommending running the streamers as pure digital streamers only and using the 6800 DAC, wasn't sure if anyone had any experience with the Icon.
Any advice would be much appreciated, thanks!
The Icon's ES9039Q2M has better specs than the 6800's ES9017, but on the test bench, the difference may be less than 3 dB (SINAD) and I doubt it would make audible difference.
1) Not sure what you meant by "then RCA out to external amp for 2 speakers.....", did you mean RAC out of the Denon or the Bluesound?
2) That imo, like you alluded to, seems overcomplicating things and I don't see any purpose of doing it that way. If you think the Icon has good quality volume control, I would just use it with your power amp for 2 channel music, and keep it separate from the Denon setup altogether.
I have no experience with those Bluesound node things, like MQA and other gadgets that NAD tends to embrace/promote; and none of those things appeal to me for whatever reasons, but I am sure experienced users will chime in and offer their recommendations.
Hi,
I have a similar setup, 6800 + 2ch power amp using a Node 2i. First of all, the HDMI on the Node is an (eARC) input AFAIK, not an output.
I tested Node 2i analog out to the 6800, but got better results by using digital out through either coax or optical. Essentially this skips and DAC to ADC step. Since I want to use the room correction that comes with the 6800 I stayed with the digital out.
Option 2 will work probably, and you can do Dirac on the Node. In that case, I'd just run rca from the 6800 to the power amp, and XLR from the Node to the power amp (if it switches between inputs automatically). Technically, the Node DACs are better, although I don't know about audibility.
My two cents worth. I think you’re really over thinking this. Plug the thing into an HDMI port and be done with it. You’ll never hear the difference.
Edit: forget HDMI, use optical or coax. Me, I’d Airplay.
Thanks for all the responses - primary reason for the complexity is so I can use the front two speakers in both the home theatre and stereo music. External amp only takes XLR input unfortunately (and a weird Naim one at that), so I can either use a RCA to XLR cable and go from 6800 directly to the power amp (and Node Icon digital coaxial out to the 6800 as a digital source only), or as I mentioned earlier in option 2 using RCA cables to connect the pre-amp out from the 6800 to analog in on the Icon, and then XLR to the amp (this way I end up essentially with 2 parallel systems for movies and stereo music sharing the front 2 speakers).
I will do some testing once the Icon arrives, but right now leaning towards the second option since it doesn't seem to have any downsides (except for being slightly more complex), and can take advantage of the (on paper) better DAC on the Icon.
Where is room EQ being performed?
The idea would be to have Dirac on both the 6800 (for movies) as well as on the Icon (for stereo music when the 6800 is turned off). Only question is whether Icon can bypass Dirac when taking the analog signal from the 6800 when playing movies.
OK, if you Dirac'd both (the most expensive path) I would use the 6800 for movies and the Node for stereo.
What I would personally do is Dirac just the 6800, and connect the Node to it digitally. This does mean you're not getting a ton out of the Node though - not sure what your reasons for buying were.
Thanks, my original motivation for adding the Icon was because 1) I needed a streamer, and 2) I was adding an external amp to run 13 speakers. At that point, I thought I can find a way to perhaps utilize the Icon (which had the dual DAC and XLR that was supposed to sound quite good) to bypass the 6800 for times I only wanted music. Then of course I started making things complicated, and probably, as others noted here, for differences that can't realistically be heard/noticed...lol
The RCA to XLR conversion cable also loses the balanced connection (only benefit is an unbalanced connection).
