Based on my findings, and from what Amirm initially mentioned w/ his earlier review of the 4700H. Concerning amp heat, internal fans. At that time, I only had the 6700H to test. I also experienced a hot area (front rt side) while using my internal (9 amp) 3 hour test run. That said, I was not surprised as to high temp area from my research prior to my purchase. During my external amp testing, with all channels set (Emotiva attached) in Pre-amp MODE. The 6700H was just slightly warm with my infinity fans off / cool across the system top. Unlike the 4700H as very warm to hot (mostly in one spot just under the ribbon cable / bracket as seen in my previous pics) this was all while in Pre-amp MODE w/ fans at high. Night and day, completely surprised me. My impression on this, primary differences top view from the system internal pics, amp design mono block layout / heat sink, no bracket ribbon cable over the top of the amps. Compare the internal pics, see the difference between systems. Of cause the 8500H as having the best component, cooling design layout.
Past weeks, I read reviews from different 4700H forums w/ people complaints of source switching, audio video pass through as bit buggy / issues from time to time. The 6700H, I yet to experience a real bug issue, so far 6 weeks. Unless you count the Cap issue which I will resolve in due time.
Someone also mentioned, having the same chip set on all the X systems? I'm beginning to question that response.
Also, what I meant by software corks = bugs
As far as your system, just keep running it hard and long as possible. Switching around sources, utilizing all feature options. And yes, two channel stereo is just LR w/ all others turned off. Ultra's Towers are completely insane at beginning @ 130 watts per (sweet spot starting line? ) or there about. Especially for the low end drivers (2) 8 inch woofers in each Tower. I tested them set to small / large both settings had impressive lows . I did not have my 2000 Pro sub on during 2 channel play / sound test. That is how good the whole 6700H and SVS had proven to be. But of cause, I went a step further (method-to-my-madness) with the Emotiva GEN-3 7 At X2 channel @ 300W per... At X 7 @ 275W per. I really did stretch the Ultra's legs and boy do they stretch! For the love of God, simply incredible!
These past weeks, I have been mesmerized. With Spotify music quality very high, upgrade.
The 6700H stand point, regarding little-to-no heat in Pre-amp Mode, totally impressed me. I physically swapped 4700/6700 systems twice just to see the differences between the two. In power capabilities, sound performance and of cause the high heat situation. Once again, I'm running in Pre-amp MODE. If you're running the systems internal amps, I'd keep the front area as cool as possible.
Well I hope that helps, Good luck!
