Possibly. You must know that these things do not have only a single power supply. The large caps and the big transformers is used for the high voltage rails for the power amps. The rest is fed via a SMPS. Depending on the type of display it might actually use a part of the high voltage supply for the power amps. If it is still a vacuum fluorescent type of display this is quite likely. So when your amp draws more current than the transformer/cap cobo can comfortably deliver, voltage wil sag, and your display will dim a bit.
Are your discussing the X6700H, or any of the higher-end Denon units? What is your source for this information? Your information isn't correct.
- It's a bit of a waste of time to have to enter all this information, but it does give an idea of the complexity of the power supplies in these units based on the X6500H. .
The power transformer has multiple windings:
o One set of windings go to the power amplifiers via a typical linear power supply with diode rectifier circuits and electrolytic capacitors
o One set of windings are for a +/- 7V supply for uses such the opamps, volume control, small signal switches. A diode rectifier circuit and IC voltage regulators are the key components here. A 5V regulator is connected to this supply for the tuner.
o One set of windings are for the fans, relays and triggers. This 12V supply includes a diode rectifier circuit and a DC to DC converter.
o One set of windings are for the DAC 5V and 3.3V supplies. User diode rectifier circuits and two IC voltage regulators.
An finally,
o Two sets of windings are for the display. One set directly supplies AC to an IC for the display. The other set supplies a simple 1/2 wave regulator.
Depending on the characteristics of these display power circuits it is possible that variations in the power amplifier outputs could affect display. Alternatively cable routing in some units could cause currents in the power amplifier supply to induce currents in the display power circuitry.
The 5.2V output of the SMPS supplies numerous (a dozen or more) secondary power supplies, which are typically DC-DC converters, for digital components.
