This is pretty much the exact question I have. Given the updated numbers, is there any (audible) reason to put a Hypex or Purifi amp on the 6700. I suspect 140 wpc will be plenty for my small room with 91 dB sensitivity 8-ohm speakers. It would be another $2200-$3000 for an NC252 or $4500 - $5000 for a 1ET400A (Apollon or NAD), and that's just for 7 channels.
Marc
There are two situations where I can hear a positive difference with a Purifi or Monolith 7x200 amps on the Denon 4700 receiver.
1. If I have a high quality stereo pair of speakers (stereo only) playing music and setup the Denon in pre-out only mode while using an external Purifi amp.
2. If I setup 7.2.4 for Home theatre action movies using pre-out only mode with the Monolith 7x200 amps. The sound is crisper and sounds crystal clear even in the peaks. It's a noticeable difference.
If neither of these examples are important to you then just use the internal amps. You will save money. You should understand the available power of internal amps will be reduced by approx 25% when more than 5 channels are in use on the Denon receiver. That may not be a big deal. If I wasn't interested in running pre-out only mode then I would just use internal amps.
