I have already done an numerical example for you in my post#213 so I am only going to be repeating part of it that is applicable here.
On the bench, Amir was getting 2 V, volume 82.5. The power amplifier output would be almost 400 W based on gain = 29 dB. For calculations see post#213.
For volume 72.5, that's a drop of 82.5-72.5 = 10 dB.
To calculate the pre-out voltage:
Vpre-out=2X10^(E5/20) = 2X10^(10/20) = 2X0.31623 = 0.6325 V.
To calculate the power amp output voltage:
https://emotiva.com/products/xpa-2-gen3
From the Emotiva website linked above, we know that the gain is 29 dB, that is, same as the X6700H
Power amp output voltage = Input voltage (that is the X6700H) pre-out voltage X 10^(29/20) = 0.6325 X 28.1838 = 18.826 V
Power amp output =(V^2)/8 = 18.826 X 18.826/8 = 39.72 W
That's of course base on Amir's bench tests that use digital input of 0 dBFS as bigguyca mentioned before.
I took a look of Spotify's website and if I understood right, they use "loudness normalization" and the normalized level is -14 dB LUFS.
https://artists.spotify.com/faq/mas...-is-loudness-normalization-and-why-is-it-used
LUFS is not the same as dBFS, so you really don't know what the pre-out voltage would be if you are streaming from them and have volume at 72.5. From what I can gather though, the pre-out voltage would likely be less than the 0.6325 V that I calculated as shown above, based on Amir's measurements using digital signal at 0 dBFS.
For ball park estimate, I would say use pre-out voltage 0.6325 V and Power amp output 39.72 W and that would be on the high side or reality.
Also, all my calculations were based on trim level settings of "0 dB". What did Audysssey set the level trims to?
For more accurate numbers, you are going to have to take some measurements and make a bunch of assumptions. Even then, you really can only calculate/estimate sort on a worst case scenario basis. That is because the pre-out voltage and power amp output "watts" at volume 72.5 or whatever depends on the input signal level to the AVR, and that various moment by moment with the music. Music is not a test tone at a constant level. So yes, that would be beating a dead horse in a sense.
If you wish to play with more calculations yourself, there are some online calculators. I developed my own in Excel because there aren't any online one that can do everything I want. The one linked below is one of the best site for such calculators.
http://www.sengpielaudio.com/calculator-FactorRatioLevelDecibel.htm
The easiest way to estimate your power need is probably to do it in reverse, that is, find out the spl you listen to with a reliable spl meter such as Radio Shack's 33-2055, use "C" weighting slow, and an online spl calculator such as the one linked below:
https://myhometheater.homestead.com/splcalculator.html
