I would suggest that for the peace of mind, it may be better for you to grab the Umik-1 and do some measurements to see how your Reference 3 are doing in your room and placement. If you have a not too good one such as my 2ch setup that shares the HT room, then DL is going to make a lot more audible improvements than a better DAC or AVR/AVP.
See that nasty suck out in the 45 to 60 Hz range, DL has done its best, I could tweak for hours and improve it by may be 2 dB, that won't really help. At least the right channel looks much better. To deal with this issue, I would need to add one or two subs and then see how well DLBC can do some wonder.
So, as others have suggested, I wouldn't worry much about dacs, just use DL, or Audyssey and see what happens.
Solid advice, thank you! You already identified the issue in your room and made the necessary steps to remediate it.
I know (I can hear) that I have an issue with bass in my room but I am currently missing basic components, that I would buy regardless of the room. I cannot wait to get started with room correction / passive room treatment, but we are moving in 3 months so I wouldn't spend on room treatment in the current room. On the other hand, identifying the exact issue in the response will be a fun exercise as part of getting familiar with REW for sure, so I'll do it and come back with the results in another topic. Speaking of measurements, tomorrow morning I'll have an audiogram too!
These are the things I'm planning to buy in any case:
- two subs to complement the mains and for more even bass across 3 seats (3 sealed to complement my ported sub for HT, because I am reading everywhere that for music sealed subs are better, however, once DLBC is engaged, I don't know how much it actually matters. When I had basic Dirac on the x4800h, I was shocked how much better my old ported sub sounds, before that it was always boomy, I never liked it regardless of placement)
- AVR for 5.3 and later on 5.3.2, with 2.1 HDMI eARC, so I can connect everything to my AVR instead of the TV
- power amp(s) at least for the mains or ideally for LCR, so the AVR would drive only the 2 surrounds (longevity, less heat)
- active heating for the x4800h because it can get hot even with the external amp
In parallel, now that I have the desktop version of stereo Dirac with DLBC, I would add an external DAC with SOTA performance, to experiment with a 2.2 system (subs and mains shared with the x4800h) with a clean, fully balanced pipeline and no Dirac downsampling. I won't attach the Wiim Pro either, to avoid the conversion from coax to balanced. This system (with a 5V DM7 for example) could also fully power an NCx500 at mid gain (requires 2.67V, so Audyssey should adjust the levels accordingly on the Denon for HT because of the lower voltage pre-outs). The bigger Purifi would be no problem for the Denon though.
Maybe I won't hear a difference between the Denon (with Audyssey) and the DM7 (with DLBC). I think everyone is different and our ears are sensitive to different noises and frequencies. My PS5 with its Ufo sound coming from its NIDAC fan drives me crazy, even after I added O-rings under the fan screws. My wife has no problem with it. Others might be totally fine with it too.
