First time posting on this site; please be gentle (and let me know if this is the wrong thread for this question
I've got an old Denon 4520ci that I need to upgrade due to its very old HDMI board. The new X4800h looks like a possible contender. I'm a big fan of the amp inside my 4520ci. So I was wondering if any of you could speak to how the amp in the new X4800h might compare to my old 4520ci. Better? Worse? About the same? I'm driving a 5.1 set of 20 year old 7.1 M&K 4ohm speakers.
If the 4800's amp isn't up to par with the 4520ci, then what about something like the Marantz Cinema 40 or the Anthem 740?
Thanks in advance!
The previous models, AVR-X4500H and SR7013 have the same power amp sections. Based on the published specs, and past history (such as the 4500 vs 7013), I would bet at least 2:1 that the 4800 and C40 also have the same power amp schematics and parts that is, they are practically identical. The Anthem 740's five main channels should have about the same rated output as the 4800 and Cinema 40, but it's remaining channels are only rated 60 W. So I would say Denon and Marantz win on this.
The 4520ci will of course do better with 4 ohm speakers, though not by much. Keep in mind, 140 W to 125 W is just 0.5 dB more, that's one click on the volume dial. So either way if you want to do your 4 ohm speakers, assuming their are truly 4 ohm nominal, full range and can take the juice, grab either the 4800 or Cinema 40 and get a suitable 4 ohm rated power amp (such as Outlaw or Monolith's, or a 300/500W buckey amp). Your can also keep the 4520 and use it as external power amp, it may look silly doing it that way, but it should work, if it works well with the M&K now.
