I finally have some time to play with REW to try and see what the heck is the deal with Denon/Marantz stereo vs direct mode vs pure direct mode in terms of whether bass management would work in each mode.
As mentioned before, my Denon 4000 series and Marantz AV8801 are long gone, I know those can do the basic management in direct mode but to actually test it out with REW, I can only use my baby Denon, the AVR-X1800H. My findings were as follows:
Stereo and Direct mode:
Crossover settings does work in direct mode, exactly the same way, and same performance as Stereo mode, except of course in direct mode, Audyssey is disabled. So the subwoofer will work too obviously, though the AVR-X1800H does not have the 2ch stereo playback menu, I think only the AVR-X4800H, Cinema 40 and above have that feature.
Pure direct mode:
- Bass management, even the basic crossover settings will not work, you can still set it to whatever you want, but it would have no effects, based on the REW graphs.
- Subwoofer will not work, unless LFE is set to LFE+M
- Subwoofer will work with LFE set to LFE+M, but crossover settings would still have no effects.
I hope this help clarify some of those back and forth post last month in this thread. If there are any particular measurements to take, just let me know, I will leave the mic out for the next few days.
Note: Again, my findings are based on using my AVR-X1800H, though I am confident that if this entry level model can do it, the higher models should be able to do the same, likely more...
Edit: Forgot to mention that, again, the 18000 does not have the 2 ch stereo playback settings so for analog input sources and using direct mode/pure direct mode, the sub-out will work but it likely don't have any bass management. It's okay for me because I would naturally be using DLBC (that has bass management) if I use analog input with my ext. dacs.
Pure direct mode:
