Denon AVR-X4800H AVR Review
Rate this AVR
    Votes: 11 3.1%
    Votes: 73 20.3%
    Votes: 194 54.0%
    Votes: 81 22.6%
If not, I will need to keep saving for the Emotiva XMC2. (Unless you think that is a bad idea too....)
For the love of god, WHY???? A quick Google search should easily turn up what a dumpster fire of a company Emotiva is when it comes to processors. Avoid at all costs.
Anyone else noticed their 4800 is now not showing as a an uncertified Roon tested device ?
Where does one look to see this?
Confusion over LFE with only LARGE floor standing main speakers.
I have a 4800. I have large floor standing main speakers capable of reproducing low bass at high volume with low distortion.
I do not have a subwoofer.
I was under the impression that if I have the fronts set to LARGE and tell the Denon I do not have a sub, the LFE channel would be sent to the large main speakers.
I am now told by some that this is incorrect. That the only way to get an LFE signal is actually to have a sub. That there is no setting that would allow the LFE channel to be sent to the large main speakers. None. Therefore, I am missing the LFE signal.
Is this correct? And, if not, if there is a way to have LFE sent to the main speakers if I don't have a sub, can you show me where in the manual or provide some other sort of "proof" or other info.
Thank you.
Thank you.
I have the same set up. Using mostly the default settings with no sub, two front as large, no center and two surround as small. I’ve tested the LFE with one of the many Dolby test videos that are on YouTube, and in my tests the 4800 does play the LFE test signal on my front speakers.
Thank you.
I think you can by using these two settings...LFE+Main and the LFE Distribution setting.
Excellent. Thank you.
Yes, it works just fine; it's unfortunate that so many ignorant people feel the need to spread misinfo/FUD. In fact, when you send LFE to the L+R mains, you will gain access to a new menu that controls the LFE volume level (0 to +10, with +10 being the "normal" setting) to limit extreme low frequency levels at your poor mains. I used the 0 setting ~24 years ago until I bought my first sub.
My X4800 is poorly - no sound from any speaker using any source, test tone doesn’t work, output channel on display is blank. Factory reset didn’t change anything . Denon think an amp may have gone :(
It’s gone for repair today.
My X4800 is poorly - no sound from any speaker using any source, test tone doesn’t work, output channel on display is blank. Factory rest didn’t change anything . Denon think an amp may have gone :(
Was this a new unit or used?
That super sucks ! Very sorry to hear of your bad luck. :facepalm:
