Most opamps are able to drive 2 kOhm, the NE5532/4 can drive 600 Ohm - both at full output swing (23 Vpp = 8Vrms when fed with +/- 15V). With a much reduced output swing like at the preamp outputs of most AVRs (less than 2 Vrms) even a load of 500 Ohm (150 Ohm for the NE5532/4) should be OK (same current as the standard load at full output swing).
Unfortunately the input impedance of the internal power amp in an AVR is unknown, so if it cannot be disconnected it's better to stay with an external power amp having an input impedance of 10 kOhm or higher - just in case...
The Denon AVR's don't use NE5532's or any other IC opamp as an output buffer. In fact there is no separate output buffer. The RCA preamp output is in parallel with the internal power amplifier input and is driven by the output of the CMOS based 8-channel NJR NJU72343. This connection to the internal power amplifier exists whether a speaker is connected to the internal power amplifier or not.
The NJR unit is rated with a 47k ohm load. The minimum acceptable load, likely with reduced distortion performance, is probably between 10k ohms and 20k ohms based on the datasheet. While these CMOS-based volume controls provide reasonable performance at a reasonable price, their outputs aren't robust. In addition to low current output capabilities vs. say the NE5532, like most CMOS devices these IC's run at low voltages, +/- 7V for the device above.
The input impedance of an internal power amplifier channel in a Denon is about 33k ohms (maximum). In parallel with the following input impedances of an external power amplifier attached to an RCA output the resultant impedance would be as follows:
An impedance of 33k ohms for an internal power amplifier channel in parallel with:
50k ohm external RCA load = 19.9k ohms
33k ohms = 16.5k ohms
20k ohms = 12;.5k ohms
10k ohms = 7.7k ohms
It is quite easy to place a heavy load on the volume control compared to its output capabilities.
The impedance calculations shown above are why it is important for Denon to change their designs such the any small signal output channel from a volume control can be connected to an RCA output and be disconnected from the power amplifier channels. This should provide improved performance at all RCA output levels.
The ability, for example, to connect the L, C, and R channels to RCA outputs and have these same channels not connected to internal power amplifier inputs would allow improved quality for the L, C, and R RCA channels, and still allow use the internal power amplifiers for the remainder of the channels.
This same change in design would avoid the serious performance impact on the maximum voltage output performance of a RCA output when the associated, connected internal power amplifier channel clips.
