D
Deleted member 28640
Guest
It seems like a die hard myth, that if the speaker is hard to drive then a 100 W or less amp cannot get the best out of it. The fact is, may be, may be not, because it depends on the maximum SPL needed from the listening position.
Just a couple examples below to show why it is a may be may be not case. That is, no such thing as I need a big amp because my speaker is hard to drive:
1) Easy to drive speakers and you listen to high spl:
You can have a big Klipsch speaker rated 150 W cont. and 600 W peak, (whatever they meant..), and sensitivity rated 98 dB/2.83V/1m (let's assume they exaggerated, so actual may be just 93 dB/2.83V/1m), but if one listens from only 12 ft, then even an AVR rated 105 WPC can drive such speaker to reference level with just 1 speaker, who listens that loud though? And to listen to 10 dB below reference level (again just 1 speaker) like a lot of people do, there will be a heathy 10 to 13 dB headroom/reserve on hand for unexpected or special moments.
2) So called hard to drive speakers:
Example: A Dynaudio bookshelf, used under the same condition as in 1):
Sensitivity: 86 dB (specs), 84 dB (actual, measured)
Impedance: 4 Ohms
Power handling: 180 W (IEC)
This one will do about 93 dB, that's 12 dB less than the big Klipsch used in 1), so for reference level one will need about 1600 W to get "the best out of it". Unfortunately, the speaker's power handling spec says 180 W so the most powerful amp one should use with it based on good/best practice would probably be about 360 W into 4 Ohms. Still, I can understand why some would consider the little Contour 20 hard to drive based on its impressive IEC power handling of 180 W, but I thought it almost laughable when I saw people claiming their tiny KEF LS50, rated:
"Amplifier requirements: 40–100W. Maximum output: 106dB. " hard to drive!! Also claimed they love a lot of power, need a lot of power to sound good....etc.etc..
How hard can it be if 100 W is required? Just about every Denon, Yamaha, Marantz AVRs can drive, based on measurements.. They can produce more than 106 dB (from 1 meter) without too much distortion anyway!! Owners of the LS50 may say, specs/measurements don't tell everything, well I happen to have a pair and had them used with amps from 7W to 500 W into 4 Ohms, and AVRs as well, and I know the answer (to the question whether they need a lot of power..) is still may be may be not.
I only used the phrase "hard to drive" in my previous post for brevity and for quick communication, I don't normally use the phrase. There are speakers that people say are "hard to drive" then there are actually speakers that are "hard to drive" that require more power and properties that outboard amplification will provide to get the most out of the speakers. I can think of several off the top of my head. I wouldn't place the Dynaudio bookshelves mentioned in the quoted post in the category of "hard to drive", and I certainly wouldn't hesitate putting four of those on a 4700 for surround/Atmos duty.
