AllCourtGuy
- Joined
- Jan 25, 2021
- Messages
- 17
- Likes
- 2
Sorry, that was a typo in my original post, it should have read that the AVR-X4700H is not available in the EU.
Thank you! That is what I wanted to hear!The different is, the AVR has a FM/AM tuner, the AVC-X4700H has not included the tuner but otherwise they are the same.
You guys are lucky, I wish we have to option to buy the AVC for a few dollars less. I am sure many of us never used the tuner.Thank you! That is what I wanted to hear!
I'm looking at using this with my Outlaw Audio M2200's for LCR. The outlaw's have an input sensitivity of 1.7v. Does this mean they aren't compatible, or a good match with the pre-outs on this receiver? In the review the quality at 1.4v decreases and it's recommended to stay at 1.1v.
1.7v is using balanced XLR, 850mV using RCA, the 4700 doesn't have balanced connections.
Actually, the guys that bought the Denon 4700 more than three weeks ago are the lucky ones. They saved $200. Maybe they can sell the 4700 now for a small loss or profit and move to a Yamaha RX-A3080?
Why would anyone want to do that? I traded my 3080 for a 4700 a couple months ago!
I had been following the prices of the 4700H and 4500H on Amazon closely to hopefully see a deal. After the price increase of 4700H, it seems 4500H is selling like hot cake. Inventory of it was fine until last night when it said 20 left. As of this morning, they're all gone.
You're lucky. It's rare that electronics like receivers increase in price, particularly an outdated model like the 4500H. But now is not normal timeThat's funny. I bought the Denon 4500 in Feb. 2020 on Amazon for $899. Now they want $1349 for a used model on Amazon. lol
I wouldn't touch a used 4500 with a 10 foot pole. My 4500 died within 6 months of purchase. These receivers can't handle the impact that occurs during multiple shipping trips. Buy new or run away!
I have the Denon 4700 but I like the higher quality DAC built into the RX-A3080, the XLR pre-outs for fronts, more powerful internal amps and lower operating heat of the Yamaha.
What features did the Denon 4700 offer you that the RX-A3080 lacked? Did you feel like the switch to Denon 4700 was worth it?
Thanks!
The DAC quality difference is questionable. Yamaha implementations do not tend to measure well, although I have not seen measurements for the 3080. I run a Peachtree Nova300 to drive my front pair, and my room is small, so I don't need the additional power for my center and surrounds. My chosen amp does not have balanced inputs, so the XLRs were useless to me. Also, I could not find a way to turn off the front amps in the 3080, so they were always running.
The main thing is Audyssey is light years ahead of YPAO.
The 4700 does run hot, but it runs much cooler in preamp mode.
I was wondering about that too. If I remember right the better DAC, ES9026Pro is only used for the main 7 channels, and the better SINAD, and DR are for differential connections. For single ended, it should drop to only slightly better than the AK4458 in the X4700H, by 1 to 3 dB at the most I would think, based on the data sheets. The ESS DAC are also subject to the IMD hump too if I understand right. I think both have specs good enough to be not the bottleneck regardless.
Did you have the opportunity to A/B the Denon 4700 against the Yamaha RX-A3080 for overall sound quality with your speakers?
Thanks!
Not in any scientific way. I heard them about an hour apart, and the main difference I heard was Audyssey, which is much better. Let's just say I did not rush to hook the 3080 back up. And as I said before, I do not need the extra power of the 3080, since my room is small, my fronts have a dedicated amp, and all speakers are decently efficient and crossed at 80Hz.
Are you utilizing the pre-out on your Denon to the Nova 300 input without disconnecting the L+R? Just curious with the pre-out voltage max at 3.5v if you noticed any issues and what your distance to speakers and max volume level has been?
The front amps are disconnected in the home theater preset. All amps are disconnected in the stereo preset. The Nova 300 is in HTB mode, which is designed for typical unbalanced AVR output voltages. No problems had. Distance to speakers is ~8'. Max volume is around 60 on the dial, which equates to average SPL in the low to mid 80s with peaks in the mid to high 90s (IIRC). There is plenty left on tap, should I want to damage my hearing.
BTW, I sent a Nova 300 to Amir to be tested. Much disappointment should be had soon!
