tineared
There are no compatibility issues with either the Purifi or the Hypex amps. The Purifi amp is a superior design and will run cooler and be more efficient. The only reason to choose the Hypex NCx500 would be if you needed more power. Buy 2 sets of these adapters for your Denon and run xlr cables to the amp. You are overthinking it.Yeah I'm not even sure I need an app this fancy. I was just looking at something to give me back my missing channel if give up on the 6XXX series Denon units and move to a 3XXX series because the 6XXX is another two grand for two more amps. They're 140 Watts versus (I think?) 105 Watts but I don't think I'd get anything out of that. My speakers are nothing fancy and I can't even get below around -40 volume on the X6500H. I just I can't even imagine how people can play lower than that or let alone reference it's just too loud for me.
So it would be nice to put that $2000 towards a three channel amp that would hopefully, weigh less, run cooler and last more than a couple of years like the Denon and or if a better Denon comes out with features I want I can get the cheaper one and continue to use the 3 channel amp for the LRC speakers, that runs cooler and hopefully will last longer.
Maybe I should just give up on the center rear channel or get an even cheaper simpler amp for just that one channel. I don't think I'd ever even notice it missing but I took the time to wire up the speaker and mount it. Plus I had heard Dirac ART was better with more speakers.
I guess the Hypex NCx500 used to be cheaper so maybe that's why folks are wondering why I wouldn't go that route. Otherwise I don't really see any reason to get one versus the other. If I purchase from Buckeye it's actually slightly more expensive, they have the same inputs and outputs, trigger and cases.
