Denon AVR-X3900H AVR Review
Rate this AVR:
    Votes: 10 4.4%
    Votes: 14 6.1%
    Votes: 146 64.0%
    Votes: 58 25.4%
I too skipped over a lot. The issue is that the HEOS part is right in the middle and has no skip. Maybe I could have abandoned it at this point but I thought there was more to configure later.
Did you plug it into Ethernet or put it on your WiFi network? There seems to be a common thread that HEOS account setup is skipped if you use a wired connection.
It's like the "famous" MS account then :)
Are dirac licences always tied to the hardware
Just often see ex dem Denons for sale but never listed with them that they have any level of dirac licences already on them which you'd sort of think would have be used if had been used as a shop demo unit ?
Wired.
Interestingly, going from digital to analog input, the amp HD3 drops from -92 dB to - 111 dB. In preamp mode (I suppose with digital input), HD3 is - 103 dB. What is going on here? Poor impedance matching between DAC out and preamp in? Distortion compensation?
The power amp is just competent but not really good. Note that in HF behavior (such as THD+N (P) at 10 kHZ or IMD), it still has most class D amps for breakfast.
I'm hoping to recieve mine next week, will report if I have to create an account or not
I actually ordered an x3800h that I saw for the equivalent of $1400USD but turned out they couldn't get it and offered me the x3900h at the same price, seems too good to be true so I'll believe it when I see it but fingers crossed! retailers are listing the 3900 at $2200USD here in New Zealand.
The IMD of this AVR is really good, one advantage could be that it does not use ESS's dac that has the know "bump", just kidding, though seriously it did almost as good as the AV10. I took another look of all the graphs, the AVR-X3900H overall performed better than all AVRs measure on ASR except the AVR-A1H (so presumably the A10H would also better, an may be in par with the AVR-X8500H (the flagship a few years ago).
Decent AVR and all, but i will be upgrading my X3700H to a minidsp one (preferably the flagship Tide16), looking at the reviews by Amir and some measurements here and there they will definitely be the upper tier avr upgrade i need.
Hopefully Amir will be reviewing some of the newer ones in the future, fingers crossed!
Thanks for the thorough testing.
AVRs are complex, and the customer interface design is terrible in my opinion. Maybe there will be an AI someday, "I plugged this into that (list,) and I want it to do this thing, draw content from X,Y, Z, in format with the greatest bit depth/non-comression by each, checked quarterly or more often, etc. and work. Configure it and help me command it."
Another graph to compare with the its much more expensive sibling/cousin is this one:
I am really surprised that the cheaper X3900H actually did marginally better (overall), there is no reason whatsoever technically speaking except the cleaner preamp output could be the reason, the only reason. The C40 did look slightly better at the lower frequency range, it has a stronger power supply so that's natural I guess.
Or again, it is the different method @amirm used, that contributed to the small differences?
What other AVR would you put up against this 3900? I don't think anything comes close and w/o caveats!
Haha I did my part searching, and only came up with two or three, all from Denon, none from Marantz (though the Cinema 30 might be one but not measured yet). The Denons are the X8500H, A1H, and A10H (by extension/projection only).
AVRs are complex, and the customer interface design is terrible in my opinion. Maybe there will be an AI someday, "I plugged this into that (list,) and I want it to do this thing, and work, configure it and help me command it."
I think this is wholly possible today with the WebUI and APIs. Thanks for the idea, might do this when the review unit comes back from its vacation.
If you refer to the operation of these complex devices I do feel for those responsible for writing the manuals and designing the GUI. For all but the most passionate, so much can be next to impossible understand and get the best performance out of these things. Straight stereo is so simple in comparison. With 6 decades of experience in playing with these things I'm still wrestling with a couple of HDMI-CEC issues, damn having 5 or 6 of these things telling each other what to do. :mad: AI and internet searches has been quite a bit of help in sorting things out.
Then beyond the technical capabilities of said gear we have the biggest contributor to that end in-room sound, the DRC software and the nut holding the measurement microphone LOL. I know many here love the hands-on, ultimate tweakablity of the highly complex DRC software available today, there was a time I did too. But today I yearn for a no-brainer approach. Give me a system where I set the mic at the MLP, click on GO, and I take a 15 minute bathroom break while the AI does all the messing about. Maybe at the end just offer me 3 or 4 instantly clickable response options to chose from and DONE. ;)
How many here tremble in fear when a friend calls saying, "I just bought this 7.2.4 HT rig and can't figure it out, would you come over andddddddddd. :eek: "
I think the biggest problem with AVRs it that they are truly black boxes. At no time do you really know what is going on inside them. There needs to be a web UI that exposes the pipeline and its settings. What is being digitized, at what rate, what DSP effects, what routing, etc. They continue to play as if these are analog products of the past but they are not. This makes testing of them nearly a nightmare. In many instances, including this AVR, I discover something later in testing that causes me to go back and remeasure a bunch of stuff! It is for that reason that this AVR had been sitting here for 6+ months before I got to it. :)
That test is the same other than if I set the gain for the amp, i.e. volume control, differently. Even if I did, the difference would not be that large.
