Denon AVR-X3900H AVR Review
Rate this AVR:
    Votes: 10 4.3%
    Votes: 14 6.1%
    Votes: 147 63.6%
    Votes: 60 26.0%
One of my friends owned this very same receiver. He said it sounded terrible from day one, but has since replaced it?! I'm not sure with what. I told him to level match with his amplifier before jumping to conclusions about sound quality differences.
I didn't like the calibration with Audyssey on my 3800. I calibrated with Dirac and the rest was history!
Was tempted with a 6700 or 10h to replace my 7200 but the 3900 looks like it measures very very well. I love the sound of the x7200w but a couple of the amplifier channels are periodic faulty and if love to upgrade from XT32 to Dirac
Is the amplification likely to be ok with a majority 4-6 ohms setup (inc Atmos) ?
I normally wouldn't be nervous as would just add a power amp or two but when I tried this recently with my Denon x7200w and a Wiim Vibelink I had really bad ground loop when I turned on my living room gaming PC. I returned the Vibelink but I am still not sure where the fault lies so to speak and I was wondering if the only fix would be an av amp or processor with balanced outputs.
That said I run a Genelec 8030C as a centre Rca to XLR and have no ground loop issues whatsoever.
Current system consists of fronts Polk R200, 8030C centre, Kef Q350 rears, Kef Q50a upfirers, and Jbl A130s rear heights
I was just concerned about all the relativey low sensitive 6ohm and below speakers
On the HEOS thing, I am not sure what "manual" setup means. As soon as you cold power up the AVR, it will pop up its wizard. I don't think there is a way to escape from it. Is there?
This account creation step was on the TV / monitor it was plugged into and could not be bypassed? I have owned several Denon AVRs, including a recently purchased 4800, and have never seen this. I might WireShark my 4800 to see what IP addresses it is talking to to find out how Big Brother Denon has become.
This is the most germane thing I could find in the manual is this on page 238:
You will need to sign in to your HEOS account to use the network features.Follow the guidance on your TV screen after setting up your Wi-Fi to create aHEOS account or sign in to an existing account.If you do not sign in to your HEOS account, you will not be able to use the Wi-Ficonnection feature.
I plug mine into an ethernet switch, so maybe that's why I have not seen that part of the setup process.
As for HEOS, it is a network player and streaming service. ALL streaming services require you to create an account, so that is not an unusual ask from HEOS. But you should only have to create an account if you use the feature. One annoyance is you have to create an account even to just use its DLNA feature to stream music from your own NAS, which is my primary use case with it. But if they want to find out I listen to a little of everything, more power to them.
Exactly right. Talking about "holographic sound stage" and all that, it is purely imagination!
have to admit I when I did a trial of DIRAC live on my PC (with and without ART) to compare with XT32 and manual EQ that I've been using with my x7200w I was quite shocked how much better it sounded and how good the plots looked in REW - never seen such flat responses with my speakers and room !
One interesting thing I noticed is that the 3900 is a slightly better 8 ohm performer (power-wise) than the 3800 but slightly worse at 4 ohm!
Without a HEOS account how can my Claude agent suspend my LG washer and dryer, and put my LG fridge and dishwasher into quiet mode when I'm watching a video? I mean, that is what's going on, right...? What do you mean, "I am the product?"
Seriously though, everyone has multiple email aliases and garbage accounts, so while annoying, not otherwise a dealbreaker for me.
Currently owning a 3800, I had a pang of jealousy when I saw the improved measurements. But I immediately upgraded my 3800 by placing a dynamo label that says "3900" over the 3800 on the lower right corner faceplate and it sounds much better already.
Yeah, hard to justify the upgrade. The 3800 isn't the weakest link in my system so money best spent elsewhere for now.
Good to see the improved measurements though. The folks at Denon probably were still smarting from Amir's somewhat disappointing review of the 3800. Not that it's a bad unit. Just that Denon could have done better with the DAC's at that time.
Anyway, thanks and credit to Amir for what he does. Whether manufacturers will publicly admit it or not, they do read these reviews and I suspect it does influence what they do.
Thank you Amir, and glad to see that Denon is very much alive with great value for money.
I was afraid that no AVR would be produced by them and am happy thst my fears wrong.
Great review HEOS account is laughable, but you did some mighty fine testing and the results are great.
Thanks once again I enjoyed it.
I think the 3900 sounds great. Nina Simone and Etta James were here tonight. Both arrived on a Denon DCD900NE. I had a pleasant evening.
I honestly do not recall the exact steps that I used on initial setup, but I do not have a HEOS account and I am not prompted to create one (via notification/pop-up).
EDIT - I should add, I do not use any streaming via the x3900h, but I am connected to my network (including internet) via a wired ethernet connection.
- Jason
That is not the way I read what happened. Do you know (factually) if there is a way to setup this particular device without an account?
I do know factually, because I did not create a HEOS account, and I have been using it since July 30th.
EDIT- also, I am not the only owner that has been using the x3900h without having to create a HEOS account.
- Jason
So when you powered it on, did you see the OSD asking you to select your language and then continue with the setup?
I used a new method to do that plot so shows the power more accurately for the 3900. So that difference may not be real.
BTW, the setting for speaker impedance is gone from the main UI. It is defaulting to 8 ohm as it should be. And to make sure no one is confused, this setting does nothing other than let them pass UL tests. Speaker can be any impedance.
The AVR-X3900H seems like a mid-cycle turn up to use a car analogy. It seems to be more refined in every area without any of the regressions we have seen in past iterations. Really, other than some noise and inference in jitter, there is nothing that hurts the eye. Seeing how the brand has been my favorite in AVR class, this is all good news. Glad Denon has not put aside their Audio Precision analyzer! :) This would be the mid priced AVR I would buy if I needed one.
Good to see Denon again offering a mid-priced AVR with product leading performance.
I still credit ASR with highlighting the weaknesses that decade earlier products were producing and holding their feet to the fire to build better.
The entire industry has been the better for it. ;)
From what I recall, there were some aspects that I set via the initial OSD setup, but others that I skipped.
- Jason
Agreed there should be little to no difference in power. It is still a 3xxx series Denon after all!
- Jason
I too skipped over a lot. The issue is that the HEOS part is right in the middle and has no skip. Maybe I could have abandoned it at this point but I thought there was more to configure later.
