Denon AVR-X3900H AVR Review
Rate this AVR:
    Votes: 10 4.4%
    Votes: 14 6.1%
    Votes: 146 64.0%
    Votes: 58 25.4%
Pretty sure if it was that simple and easy, more than JBL would have done it at the moment. I don't think those JBL MA AVRs are selling well.
I've never myself made the JBL --> AVR connection. Speakers sure, but not electronics
For the midi systems Denon has the M-series which is AB and the N-series is class D, so it appears that in this case both sell
I have no clue what Denon series you're talking about. Do you mind posting a link?
OK, so are are not AVRs so I won't keep talking about this beyond this post.
RCD-M41 (class AB)
RCD-n12 (class D), n9 has been tested here @ ASR
n12 is nowhere near Wiim Amp Ultra class, so that's obviously a better device (2x65w, higher distorsion vs 2x200)
AVR are complicated devices so just the class of the amplifier won’t make me buy or recommend a different brand. Although it would be nice to see denon switch, its not likely.
RCD-M41 (class AB)
Cute little lifestyle marketed products that might be most appropriate for 2nd and extra rooms background music suppliers but in-general not
geared towards the serious enthusiasts that make up the bulk of our membership.
Impressive amounts of power in these AVRs, Although movie soundtracks rarely call for all channels peak, i think the class AB waste heat at the more quiet parts could be more an issue.
I have the X4800 - so same generation of power amps - and it stays remarkably cool.
Thing to keep in mind is: for the digital video generation (anything in this century!) - the main source of heat in AVR/AVP's has always been the processing chips - both video/hdmi and DSP chips.
Heat issues have been caused by traditional audio engineers designing systems which produced heat like a computer system - because the components are NOT traditional audio components, but in fact a computer with a power amp tacked on the side....
And as anyone who has worked with PC's in the last 40 years can attest, heatsinks, fans, temperature control are absolutely critical ....
On my 2008 generation AVR and my 2013 generation AVR, you could literally fry an egg on the top of the AVR ... you definitely could not sit your hand on there without severe discomfort.
On my 2021 generation AVR - that heat was gone - it ran cool under pretty much any conditions - tear down photos showed heatsinks on both DSP and HDMI chipsets (a major missing component in previous generations!)
My current Denon X4800 (2023 generation) also runs admirably cool - even when driving all 9 speakers during a blockbuster (power amp heat) - and stays cool under any conditions (the 2008/2013 generation AVR's ran hot even when quiescing - as they were processing digital signals - it wasn't the power amp getting hot!).
I would urge anyone who owns (or plans to own) an AVR/AVP to ensure it has sufficient fresh air flo, front to back and from the sides - it needs space to breath..... (enclosing it in a sealed cabinet will do it no favors!!!)
But we seem to have exited the bad old days, when AVR's fried themselves (all brands!) - and typical AVR lifetime was circa 3 to 5 years due to heat....
I am hoping that my current AVR will last at least a decade.
Different companies have different philosophies behind how to handle heat. Companies opting for heatsinks on the HDMI card and other areas will probably have more reliable AVRs than those that don't. The biggest knock on their offerings? They tend to be more expensive from the start (but worth it in my mind).
Here's hoping so. ;)
My X4700H with a Noctua NF-A20 PWM, Premium Quiet Fan using the included "Low Noise Adapter, voltage reducer plugin", blowing up.
It never seemed very warm but it was used in the preamp only mode. OTOH you can never run a product "too cool". JMHO ;)
Great suggestion! Love Noctua's fans and I use them exclusively for all desktop and server rack PC builds. Now I'm inspired to add Noctura to my A/V rack as well.
Swedish LTS has tasted several rcd-m midi systems and found them to be transparent. Currently a rcd-m39 is feeding my 8000 euro speakers and if I covered the unit up most of you would think I'm using much more expensive electronics with tons more power.
It's rather that people think they know, think they need product X for pure audio. But as I often say, the limitations lie mostly elsewhere; speakers, rooms, ears, source material etc
Why is vinyl played in million dollar systems to begin with at hifi-shows? Most don't know the specs of vinyl, even so called "enthusiasts"
The N-series is budget class D circuitry, the M-series is a lot better
What both obviously lack is room correction
Wouldn't debate on that point, but cramming all those components in those tight spaces will in all likelyhood cause heat related issues sooner or later.
Also don't want to get into any discussion of pricing, but all else being equal, the bean counter guys did have to look at the cost of the included components and cut a few corners here and there to meet desired price points with these guys. I believe long term reliablity will suffer at some point.
Yep, that same fan now sits on top of my AV20 PrePro, cooler is better. ;)
Oh your baiting me, you know what I think about using 1960s audio quality sources in modern Hi-Fi's. :p
Nah, but I don't want this discussion to continue either. Vinyl obviously can sound terrific in a great system, especially with the right speakers. If it sounded bad then no-one would demonstrate high-end systems with vinyl as a source.
Take any phono-preamp that has been tested here @ ASR and it's under the specs of the CD-player in both Denon units. And that's also why the poor class D amp in the N-series can also be enough. The speaker SINAD is likely even worse.
Not a real concern unless the speakers are a heavy load. m39 has plenty of ventilation holes, N not so (it's plastic on top) but class D efficiency helps
I'll have my x3900h today and and it will obviously run much hotter
I'll disagree with you there. Yes the amp sections can be a major source of heat depending on operating class, bias levels, load, etc.
But even my little Emo DC-1 DAC can run fairly hot just idling, in fact I added taller feet to get better circulation since the factory feet had it sitting only about 1/4 off the desk almost blocking the venting on the bottom panel.
I'll also quote @dlaloum post above for his take in components internal heat generation.
Yep - I did this with my 2008 AVR.... right up until I did a series of measurements and found that there was measurable additional noise injected when the fan was on.... was it audible subjectively - no - but it was measurable.... I ended up removing the fan, and the unit ended up frying itself...
I used an Asus AVR cooler - similar to the current AC Infinity Aircom coolers.
It would be nice to know if anyone has done SINAD tests with the Aircom coolers on/off.... The fans don't put out a heap of EM interference, but they do put some out, and they tend to be located right above the most sensitive DAC circuits....
P.S. :I am a big 'fan' of the Noctua fans...
@dlaloum , how did you measure the electrical fan noise added to the audio?
I would not power any of those fans with the USB port on AVRs, not that it would introduce noise, but it might, depending on the specific fan. My Noctua fans don't even use USB so that would be a moot point.
I doubt that, as you said, not a heap but I would say next to nothing. More likely harmonics from the speed control depending on the fan/controller, and especially if you power it with the USB port on the AVR.
