Denon AVR-X3900H AVR Review
Rate this AVR:
    Votes: 10 4.4%
    Votes: 14 6.1%
    Votes: 146 63.8%
    Votes: 59 25.8%
Hello All,
I am new here - I am nowhere even close to being as knowledgeable & technical as most here so please consider me as novice & somewhat limited in my ability to understand technical terms/aspects & any deeper understanding - hopefully, in time, I will learn from all the valuable help, input & guidance I can hopefully garner here.
I am in the UK & I have an AVR-X4400H alongside a 12 Channel Rotel RMB-1512 External Power Amp & have an 11.1 Channel Set-Up in an Auro-3D 11.1 Layout with Front Height Centre & Voice Of God Speakers - Standard 5 Ear Level Speakers & 6 Height Layer Speakers (No Back Surrounds).
The X4400H handles this very well indeed but my understanding or what I have heard is that the Auro-3D implementation on the X3800H is better - by how much, I do not know & then considered upgrading to that since being a 4 year old model & being discontinued, I was hoping to pick one up at a good deal.
However, the available X3800H's are even more costly than they were last year (£899) & the newer X3900H is not that much more at full RRP - I expect deals to happen around Black Friday, Cyber Monday, Xmas & New Year Sales at which time an X3900H may very well be cheaper than buying an X3800H now - for example the X3900H is at full RRP of £1299 & the X3800H £1099. One retailer even offered me an X3900H at £1150.
I am not concerned about things like Power Output etc as I will be using my external Power Amp for that - I found that the X4400H would get concerningly hot & to mitigate against this & hopefully get a more dynamic sound, got the external amp.
My main aim (whether X3800H or X3900H) maximising & getting the very best Auro-3D experience via both Native Auro-3D & the Upmixer is important to me (as well as all the other Surround Formats), this peaked my interest in initially possibly getting a X3800H but as I stated, it is now a 4 year old discontinued model & imho, the current new asking prices are just way too steep & way to close to the newer X3900H which should be current for the next 4 years assuming the same release time pattern.
If the Auro-3D is better on the X3800H than on my X4400H, has anyone experienced or know by what sort of level - is it just a very minor level or a notably better one?
Now again, same question with regards to the X3900H then with it's newer DAC etc - is it's Auro-3D implementation even better than that of the X3800H? Can anyone please tell me what it is superior at compared to the X3800H in terms of Surround Sound Formats, Sound Sound Features etc? Will the X3900H offer a better delivery & more 3D, cohesive, more effective/convincing Surround Sound experience with all the other formats please? If so, how & in what manner please?
If there is a notable difference between the X3800H & X3900H for my needs, then I will likely steer towards the X3900H new which means a higher cost for me but if there is only a marginal improvement, then in all honesty, I will likely look on the classifieds for a used X3800H instead & hopefully save a few hundred pounds.
Apologies for any errors or assumptions I may have made.
Thanks Kindly!
There are known to have been updates to various decoders and upmixers (Dolby, Auro, haven't heard about updates to DTS...).
Details are thin on the ground, and the manufacturers generally don't provide any information on specific versions of the decoder software that they host.
Having said that, a number of people who updated their AVR's/AVP's from the house of Marantz/Denon .... have remarked on immersive improvements.... those improvements are not supported/justified by improvements at the hardware/SINAD level.... but are highly likely to be related to updates to the decoding software.
So even if using the exact same identical features, and audible improvement is likely between the X4400 generation and the current X3800/X3900 generation.
Additionally, the current generations support Dirac ART (at additional optional cost) - it isn't cheap, but it can achieve room level improvements that are unattainable in any other economical manner (ie: it would require a custom built listening room to achieve similar results).
I ended up purchasing an X4800 about a year back.
If I was in the market now, I would be likely to try to find a refurb or used Xx800 and put the savings over an Xx900 elsewhere....
I don't believe the simple SINAD improvements between the x800 and x900's is likely to be audible and worth the difference.... and the x800 already has all the features I look for.
I look on in interest, but see no need to upgrade to the latest generation - let's see what they come up with over the next couple of generations!
That is normal if you define maximum output as when the output signal starts to clip, because at that point distortions will also start to climb and climb more rapidly it the output continue to increase. So, naturally the peak performance, in terms of peak SINAD will be at below that "maximum" output voltage.
oh, yes. What I meant was, to rephrase better, why do they design it so the outputs are clipping below the maximum output. Seems weird.
That may or may not be the case, but I don't see evidence of "they" design it that way, assuming "they" refer to the likes of Denon, Marantz? Do you have a specific example in mind? It might work out that way if you pick the "maximum" output as such 150 W for the Denon AVR-X4800H, then obviously the output would be clipping below 150 W, but if define/pick the maximum output as 125 W, then the output would not likely be considered clipping below that point. So, yes, no, it depends.
It is not maximum output, but characteristic measured at a given volume. Amir provided 2 characteristics, at volume 83 and 90. See, there is a different clipping point for them and probably different noise level. And actually important is not the clipping level of preamplifier, but the level, at which power amplifier is reaching clipping. Or more precisely, you should include headroom to that estimation, because music is not a simple sinus, and you play music at lower level to avoid clipping at peaks.
That Rotel amp is not going to give you more output than the AVR-X4400H. If you really want to have more output, go with one that is rated at least 200 W 8 ohm, 300 W 4 ohm. Something like this one: https://www.buckeyeamp.com/shop/amplifiers/hypex/nc502mp/6_channel
The AVR amp can feed your height and surround speakers unless they have relatively low sensitivity and/or far away from you seating positions.
Hi peng!
Interesting - I had learned online/YouTube/reviews etc that when an multi-channel AVR like my X4400H - the specs say for example it is 140watts - that is not across all 9 Channels - it only for usually just 2? When all channels are employed, then the power output drops to around 50 watts per channel & that it will not be able to deliver 140 watts continuous to all channels simultaneously - is that wrong?
Thanks!
Greetings! May I ask about the TV and the source devices you use with your X440H?
Hi Tre2023,
My TV is a 55" LG G4 OLED. Currently, I only have a few sources: Samsung Blu-Ray Player, VU+ Duo Satellite Receiver, A Freeview Set-Top Box, Amazon Firestick 4K.
I plan to get: 3rd Gen Apple TV, An NVidea Sheild Pro or Alternative, 4K Blu-Ray Player, Access to a Friends Plex Content & maybe a gaming system - X-Box/Playstation.
The X3900H was recently on sale but no more. I’d wait for it to go on sale again to get the latest features on the newest model. Though, the X3800H is currently on sale.
The X3900H adds 1440p support and AMD Freesync Premium for gaming from an XBOX Series X/S.
The X900H features MPEG-H for those using a Fire Stick 4K or Fire Cube Gen 3 with Amazon Music Unlimited and want to experience 360 Reality Audio tracks as well as Dolby Atmos tracks.
If using HDMI-CEC, LG TVs get finicky when exceeding the number of devices they support.
Hi peng!
Thanks!
There are constraints to any amplifier - one of those constraints is the amount of current that the power supply can feed it...
Often, especially for multichannel amps, the size of the power supply will constrain the maximum power output when running all channels simultaneously.
The manufacturer designs each channel for its full power specification individually - which allows individual channels to have peak output at specification levels - but given that in actual use, most of the channels will be running at much much lower levels (1 to 3W continuous average/RMS is common for normal listening levels) - they save money in the sizing of the transformer and capacitors.....
So when testing in stereo only - with 2 channels powered - the power supply will typically be ample to drive them to their maximum.... but as soon as you run 5 or 7 channels, you will typically find the system clipping at lower power levels.... and if running 11 channels or 13 channels - the power available per channel simultaneously is lower again.
Whether or not that will be an issue for any individual system, depends on a lot of different things - room size, how absorbant furniture is, efficiency of the speakers, preferred listener SPL levels etc...
I like to listen typically at an average level of around 72 to 75db at the listening position - and at that level, my main speakers are being fed between around 1W RMS - and assuming 20db peaks (as per the Dolby / DTS standards) peaks in worst case for 1W continuous are circa 128W for momentary peaks. (my speakers are relatively inefficient @ 86db/w and the room is very large - so for many people the power requirements would be lower!)
The power supply is easily able to feed all the channels for peaks (which will typically come from the capacitor bank rather than the transformer)
There are other things to consider - the power supply capabilities becomes even more critical if you have speakers with impedance that dips down below 3ohm for certain frequencies (often at subwoofer crossover frequencies) - as the lower the impedance, the more current they require. - Another thing that can be an issue for many amplifier designs is stability - many amp designs can become unstable into low impedance loads - so speakers like mine with a minimum impedance of 1.6ohm can cause trouble with many AVR's (I am happy to say that the X4800 handles my speakers well)
So you are quite right in querying the "simple" power spec for the AVR - the real limitations/capabilities are a lot more complex.
Hi peng!
Thanks!
Some of what you heard or read may not be accurate. Below is one that you should read and come back if you still have questions:
In general, D+M, like all AVRs, and many separate power amplifiers will rate their all channel simultaneous output lower than their 2 channel driven outputs. For AVRs such as D+M's (Denon, Marantz), if the AVR is rated 100 WPC, then it will do about 70 WPC with 5 to maybe even 7 channels driven simultaneously. This is just roughly speaking, the actual outputs will depends on other factors such as the specific speakers, ambient temperature, how well ventilated, are external fans used etc.
Also, for most practical use such as watching movies, even if the all channel driven ratings are less than 50 % of the two channel driven numbers would most likely be fine because real world movie and music contents do not result in continuous output level like the bench test signals do. If you listen to constant sine waves using all channels simultaneously, then you would need to be more concerned, but you will never do that, I assume.
Below is one example of bench tests that might help you see the bigger picture.
This test shows the 105 W rated AVR-X3700H outputs 95% or its 2 channel driven rating. The chart labels it as 61% only because at 1% distortions, the 2 channel driven outputs was much higher than the rated output that was based on 0.08% distortions.
When comparing the measured output, one has to keep in mind the test conditions, one being the distortions level used, most amplifiers can output more, in some cases, a lot more, if higher distortions is acceptable.
One can present another graph - total power delivered:
1 channel - 163W
2 channels - 276W
3 channels - 357W
4 channels - 420W
5 channels - 500W
That looks quite impressive, but it is probably a short time test. I don't think AVR with AB amps can support that much heating for a longer time. X3900h has 660W of power draw in specification. Which means it can delived about 5x60W average.
Hi,
I’m currently choosing between a few AVRs, got an arcam avr850 with dirac right now and looking for remplacement :
  • Denon X3900H: ~€1,270
  • Denon X4800H: ~€1,650
  • Denon X6800H: ~€2,590
  • Onkyo RZ70: ~€1,850
  • or waiting for the upcoming RZ51 / RZ61 / RZ71 in 2027.
I’ll be running 4 subwoofers 5 speakers and 4 atmos.
The X3900 looks nice in terms of DAC performance and measurements, the X4800 has better construction and slightly stronger amplification, the X6800 is more complete but significantly more expensive, and the RZ70 has much more power/current capability but is limited to 2 independent subs and doesn’t support ART, but I like to have a nice powerful unit like my avr850.
Which one would you choose today?
1 channel - 163W
2 channels - 276W
3 channels - 357W
4 channels - 420W
5 channels - 500W
Right, short term for sure, and if I remember right, Amir has confirmed that those tests were for short durations, I don't know how short, my guess is, probably just 10-30 seconds but again it is just my guess.
As to the 660 W power draw, that is one of those vague spec that different manufacturers likely define it differently. Years ago Yamaha, like Denon provide just one number but in recent years they provide two numbers such as the one below:
That's Yamaha, not sure what the Denon's "Maximum Power Consumption (All ch driven 10% THD)" is for the X3900H but my educated guess is that it would be higher than 660 W. So the "Maximum", would likely indicate short term rating, and at output way pass the knee point of the output vs THD curve for sure.
Denon might have similar information floating around on the internet but I have not been able to find any.
Yamaha RX-A6A (from their downloadable User Guide):
500W output means over 1kW power draw. This could be what Yamaha is calling "maximum power consumption". Without blowing fuses, but a short term capability. Till thermal sensor shut it down.
Thanks Amir. Great review. I have been thinking of replacing my Anthem MRX-540 with a Denon or Marantz, due to all of the features they have. This may be the one.
Impressive amounts of power in these AVRs, Although movie soundtracks rarely call for all channels peak, i think the class AB waste heat at the more quiet parts could be more an issue.
Yes, I might have bought a class D based Denon instead if these existed
Perhaps with the case of 3900 it could actually do 11 channels without the need of a power amp for the last two channels
It's a direct replacement of the 3800, which means only 9 channels internally powered. You'll have to go to the 6800 for 11 channels powered.
I know, saying they could perhaps make class D AVR more easily than AB.
Less cooling requirements equals more space for other things
Pretty sure if it was that simple and easy, more than JBL would have done it at the moment. I don't think those JBL MA AVRs are selling well.
