Denon AVR-X3900H AVR Review
Rate this AVR:
    Votes: 10 4.4%
    Votes: 14 6.1%
    Votes: 146 63.8%
    Votes: 59 25.8%
I keep hearing that it's meaningless, but no one watches movies in Pure Direct, listens to Spatial Audio in Pure Direct, or games in Pure Direct.
There's no reason NOT to start base-lining this.
Agreed.
I am uncertain there is base-line measurement using DSP that can be standardized across brands.
Yes - but although you could baseline on an unprocessed full signal chain.... the actual DSP in action with DTS/Dolby will impact the SINAD negatively in any case - before adding a whole suite of additional tests (and hours of additional test time for each iteration!) - you would need to really understand what it is that you will gain from it, and whether the data provided will in fact be meaningful.
My point is, it sounds great, but in fact it won't be meaningful or useful... so why do it?
What's the SINAD result of any processor using multichannel upmixing? If you can't answer you just proved why it's useful. no one really knows if one brand is better than another or if they're all the same.
IMHO some basic measurements would be interesting. Like REW scan with DRC on and off. Or characteristics of crossover. For example I suspect that LPF filter for LFE channel of LX505 tested on ASR is wrong. Would be great to have a direct check.
Agreed! And as for "Nice to see continued support to turn off the amps so as to use the pre-out without the unit reducing performance" agreed as well, an important option.
BUT Denon why the heck is performance best at not-maximum preamp output voltage?
That is normal if you define maximum output as when the output signal starts to clip, because at that point distortions will also start to climb and climb more rapidly if the output continues to increase. So, naturally the peak performance, in terms of peak SINAD will be at below that "maximum" output voltage.
He did say "yes".. so it seems that no one is disagreeing on that point. The point might be (just guessing), that is it worth the effort? Just about anyone on ASR may think they can hear distortions that become offensive if one cranks the volume high enough, but not too many seem to say the same about DSP such as listening to Atmos, DTSHD etc.. Again, if it only takes Amir 20 more minutes to do a bunch of measurements to show the impacts/effects on SINAD when DSP is engaged to play Atmos (an example), and/or DLBC, ART, etc., we would have seen it done already. But if it takes "hours.." as dlaloum used as an example, then I guess we might expect the answer..
Good discussion. We should be able to get this done.
I'm not sure what standards the technical experts believe is appropriate, but I'd like to see any measurements performed with Dolby Atmos upmixing and or DTS Neural X (usually 3.x) upmix. A test for Room Correction on and off seems pretty straight forward...
Sorry I'll post in another thread moving forward.
Recent changes to the Dolby toolkit, led to noticeable improvements in immersion (reported subjectively by multiple users) - but how do you identify whether that is improvements to the hardware base - identifiable in SINAD measurements - or much more sophisticated adjustments to how virtual signals are steered to physical channels?!!
The processing also involves adjustment to signal levels (and sometimes frequency dependent adjustments too) - all of these will definitely impact on SINAD...
But the SINAD outcome, will not reflect the subjective quality of the outcome - with more processing happening, the SINAD may go backwards, while the immersion / sound quality improves .... a lot of the processing is related to how sound is perceived rather than how it is measured, and SINAD is a very very awkward measurement when perceptual impacts are considered.
I've been saying this for a long time, but we do not have quantitative/objective measurement methods that provide a really good toolset for evaluating the perceptual immersive impact of a system and its processing.
Your implied question - where is the objective measurement for a multichannel surround system ? - is apposite... But SINAD just isn't it. SINAD is a hammer to crack a particular type of nut - and not much use in the delicate surgery of analysing these surround setups!!!
Really all we have at the moment, is traditional mono measurement tools, applied individually to individual channels - and the question of where are measurements relevant to the Gestalt of the multichannel system are very relvant - and the gap is clear!
In these posts, I've seen upmixing mentioned, Atmos (and dtsX) mentioned, and Atmos upmixing mentioned, often interchangeably, yet these are all different.
Upmixing, meaning taking a PCM signal and processing through the Dolby (or dts) upmixer to create synthetic multi-channel audio, creates distortion, clearly audible in a decent system. It hardly seems worth the effort to attempt to measure. My own experience is that the better the electronics, the more audible the distortion.
A good Atmos source, decoded (not upmixed) through a good system, does not seem to introduce distortion, at least, not audible distortion, and contra upmixing, better electronics provides a better Atmos listening experience.
I find it difficult to believe that a complex Atmos output can be measured to establish what, if any, degradation is caused by the decoding software. One thing that I have observed is that electronics with better fidelity, as defined by the SINAD measurements posted on this site, provide better quality audio, and that SINAD measurement is useful for comparing products, along with the other measurements made.
Perhaps someone could create a blu ray with a test tone mixed and mastered as an Atmos object, and that could be used to take a measurement to get some idea of the extent to which the Atmos decoder may impact SINAD. Of course, the decoder is updated from time to time, so the measurement would only be valid for the particular decoder version and the particular electronics used in the test, but this does not seem worth the effort, other than for hobbyist entertainment.
I am not convinced that the Atmos decoder has much, if any, negative impact on any of the criteria measured in the reviews on this site. Upmixing does, and for that reason, I avoid it.
I think this disk does this: Spatial Audio Calibration Toolkit
Hello All,
I am new here - I am nowhere even close to being as knowledgeable & technical as most here so please consider me as novice & somewhat limited in my ability to understand technical terms/aspects & any deeper understanding - hopefully, in time, I will learn from all the valuable help, input & guidance I can hopefully garner here.
I am in the UK & I have an AVR-X4400H alongside a 12 Channel Rotel RMB-1512 External Power Amp & have an 11.1 Channel Set-Up in an Auro-3D 11.1 Layout with Front Height Centre & Voice Of God Speakers - Standard 5 Ear Level Speakers & 6 Height Layer Speakers (No Back Surrounds).
The X4400H handles this very well indeed but my understanding or what I have heard is that the Auro-3D implementation on the X3800H is better - by how much, I do not know & then considered upgrading to that since being a 4 year old model & being discontinued, I was hoping to pick one up at a good deal.
However, the available X3800H's are even more costly than they were last year (£899) & the newer X3900H is not that much more at full RRP - I expect deals to happen around Black Friday, Cyber Monday, Xmas & New Year Sales at which time an X3900H may very well be cheaper than buying an X3800H now - for example the X3900H is at full RRP of £1299 & the X3800H £1099. One retailer even offered me an X3900H at £1150.
I am not concerned about things like Power Output etc as I will be using my external Power Amp for that - I found that the X4400H would get concerningly hot & to mitigate against this & hopefully get a more dynamic sound, got the external amp.
My main aim (whether X3800H or X3900H) maximising & getting the very best Auro-3D experience via both Native Auro-3D & the Upmixer is important to me (as well as all the other Surround Formats), this peaked my interest in initially possibly getting a X3800H but as I stated, it is now a 4 year old discontinued model & imho, the current new asking prices are just way too steep & way to close to the newer X3900H which should be current for the next 4 years assuming the same release time pattern.
If the Auro-3D is better on the X3800H than on my X4400H, has anyone experienced or know by what sort of level - is it just a very minor level or a notably better one?
Now again, same question with regards to the X3900H then with it's newer DAC etc - is it's Auro-3D implementation even better than that of the X3800H? Can anyone please tell me what it is superior at compared to the X3800H in terms of Surround Sound Formats, Sound Sound Features etc? Will the X3900H offer a better delivery & more 3D, cohesive, more effective/convincing Surround Sound experience with all the other formats please? If so, how & in what manner please?
If there is a notable difference between the X3800H & X3900H for my needs, then I will likely steer towards the X3900H new which means a higher cost for me but if there is only a marginal improvement, then in all honesty, I will likely look on the classifieds for a used X3800H instead & hopefully save a few hundred pounds.
Apologies for any errors or assumptions I may have made.
Thanks Kindly!
Hello All,
Thanks Kindly!
Welcome to ASR!
I can't answer your Auro question but I think getting the 3900 over the 3800 is a no-brainer for you specifically because you're using external amps and can potentially benefit from the higher SINAD. The decision is even easier since you seem to imply the pricing b/w the 3800 and 3900 is not that different. The 3800 came out in 2022 so resale value will drop like a rock if it hasn't already.
I am in the USA & I have an AVR-X4400H with an attached license for MultEQ-X. Moreover, I use the preouts, so all audio is routed to an external amplifier (Emotiva LPA-7).
More generally beyond @Suave's question, I'm wondering if are any pragmatic reasons for upgrading from the AVR-X4400H with MultEQ-X to the X3900H given our usage is primarily watching movies but I am still only at 5.1 surround setup.
Only if you plan to go up the Dirac technology tree. If you don't think you'll grow beyond 5.1, I don't think Dirac ART makes any sense.
My X4000 was still running like a champ when I retired it a few years ago for a refurb X3800h - mainly for 4K HDMI support (your 4400 already has it) and then a short while later to add Dirac and use 2 sub outs independently (and adding a 3rd tomorrow :) ). I also don't see any need to upgrade in your case unless you want to do 5.2 or beyond.
Then the answer would be no. In that case, you have the luxury to wait until you can get a super deal that you cannot resist, on the X3900H and at that time if the x4400H is in great condition you can sell it easily for a reasonably good price, may be enough to buy the Dirac Licenses.
Hi All,
My profound apologies as I forgot to mention this in my prior post as the X4400H has Audyssey MultiEQ XT32, I did buy the additional Audyssey paid Smartphone App so will have use of that. I am only using one Subwoofer which is a Velodyne SPL-1200 Ultra. All my speakers will be the Anthony Gallo Acoustics A-Diva SE's (9) & the L&R Ear Level Surrounds are Monitor Audio Shadow 25's - I had to deviate to either these or their KEF equivalents as there is an inward opening door at the RS position which would smash into the speaker each time so had to get a flat, wall mounted type so there could be clearance.
I will not, for any foreseeable future, be using DIRAC in whatever forms it may be - my skill & knowledge level is simply too primitive & the cost for me is prohibitive. I understand there are other options like OCA Acoustic X mentioned earlier & OCA Evo Neuron that I can try & explore - only just learned of these & according to Google AI, they will give me 80%-85% of what DIRAC can & as I live in a Country of "Rip Off Prices" & better described as "The Land Death By Taxes", that should do me just fine for the time being - DIRAC at my knowledge & skill level sounds like something akin to giving a Formula One Car to someone who just passed their Driving Test!
Folks, this is the first time I am using an external Amp for all Channels - may I ask, do you feel the 12 Channel Rotel RMB-1512 Power Amp will be a good match for any of the Denon AVR's I am considering - I got it for a good price & I like Rotel - it gave me the benefit of having all the Channels in a single unit that is not the size of a Truck, has a 12V Trigger Connection so it can be switched on/off automatically by the AVR Remote & I understand that being Class D Amp, it should run much cooler. What improvements can I expect from it over the internal Amps on any of the Denon's please?
My connotations on the Auro-3D implementation & General Surround Sound Modes are:
1) Notably better on the X3800H than on the X4400H > Likely getting a Used X3800H
2) Notably better on the X3900H than on the X3800H > Likely getting a New X3900H
3) Marginally better on the X3800H over the X4400H > Likely Keep the X4400H
4) Notably better on the X3900H than on the X4400H > Likely getting a New X3900H
I just need to be able to justify the cost of a new X3900H - do not want spend all that extra cost only to then feel deflated with the Auro-3D & other Surround Sound Formats delivery & find there is only an incremental improvement over the X4400H so I am earnestly hoping all the kind folks here who may know can guide me & give me insights from their experiences!
Many Kind Thanks!
That Rotel amp is not going to give you more output than the AVR-X4400H. If you really want to have more output, go with one that is rated at least 200 W 8 ohm, 300 W 4 ohm. Something like this one: https://www.buckeyeamp.com/shop/amplifiers/hypex/nc502mp/6_channel
The AVR amp can feed your height and surround speakers unless they have relatively low sensitivity and/or far away from you seating positions.
I did the full external amp thing with a NAD Pre-Pro (very large and heavy Sony TA-N80ES; 2x TA-N77ES and TA-N55ES). I'm back to an AVR + KH150 actives for L-C-R, powered subs (SVS SB5000's), and use on-board AVR power for surrounds and heights. Really no need for external amplification except for MAYBE L-C-R (and likely by the nature of being active) IMNSHO.
120W to 200W is really not much more output AT ALL! Even 120w to 300w is barely 3dB if your speakers aren't already into power compression by then!
Hello All,
Thanks Kindly!
Greetings! May I ask about the TV and the source devices you use with your X440H?
