It's been that price for a couple of weeks now. No doubt this is the final reduced MSRP since they're clearing inventory to make room for the current 3900.You can buy the 3800 for 1300 from the Denon website.
Unless the Mc is used elsewhere, sure use it with the AVR.If thinking about using this for 2.2 listening, does it make sense to use an external amplifier? I already have a Macintosh MC152 which, if I'm doing the calculation correctly has a sinad of either 93 (at rated output) or 105 (below rated output). Seems like it makes sense to use it as an amplifier and use the X3900 as a preamp.
Seems like a good match, but you can't reduce the voltage, it will just vary between 0 to whatever the maximum output voltage your need for your listening level and contents you listen to.My second question is that Amir's measurements indicate 104 db at 1.6 volts and can go up to 4 volts at reduced performance. The input sensitivity of the amp is 1.2 volts for unbalanced. Does that mean ideally I would reduce the voltage? Final question - how does one reduce the voltage? I searched the manual and didn't see a setting mentioned for adjusting output voltage on the preamp section. (My favorite section of the manual is about adding an external amplifier - "By adding a power amplifier to each channel, the realness of the sound can be further enhanced."
The new x3900h costs 1329 euros in the Netherlands. The x3800h around 1050 iirc.
I believe @terfenol-D was only referencing the pricing of Denon USA. You don't understand how good you folks in the EU have it when it comes to pricing vs our stupid tariffs!The new x3900h costs 1329 euros in the Netherlands. The x3800h around 1050 iirc.
Yes it is time to get up to dateI've been running a Yamaha RX-V1600 for nearly 20 yrs now. It's a 38lb beast and sounds great (to me), but lacks modern digital processing. I've decided it's time to finally upgrade. In my area, I can get the Denon AVR-X3900H at retail ($1850) or the "older" models such as the X4800H for 30% off (GovX discount code). That puts the 4800 at $1960, only $110 more than the 3900, which doesn't seem significant.
Any thoughts or opinions? I'm running a 5.1 setup with Paradigm Studio 60 v3s and the Paradigm CC-470 v3 center, a Velodyne 10" DLS3750R sub and some fairly small rear channel Definitive Technology Pro Monitor 60s (which I plan to upgrade). The Paradigms are fairly power-hungry. I don't need extra channels, but I want headroom to play movies loud and get the most from my speakers. I already finished the basement with double layers of 5/8" sheetrock, green glue and leaf springs separating them from the joists. I don't plan on cutting holes or running new wires to add additional speakers.
I think the amplifiers and possible build quality in the 4800 may justify the extra price, but it's also 3+ years old now and I question whether the 3900H would be the better choice?
How did you end up going with the Channel Expander?The 3900 has different ic, a channel expander, and a orher options that allow it to stand out and gibe some audible differences. I plan on setting mone up this weekend. The problem is I have neve found a really good reason to put my 4500 up. It just sounds so good.
Probably the only difference between AVR and AVC is that the later has no radio tuner, but it has an additional RCA input instead.It does not seem like the AVR models are available in my country. Can I expect the same results from the AVC-X3900H?
3900 Pros:I've been running a Yamaha RX-V1600 for nearly 20 yrs now. It's a 38lb beast and sounds great (to me), but lacks modern digital processing. I've decided it's time to finally upgrade. In my area, I can get the Denon AVR-X3900H at retail ($1850) or the "older" models such as the X4800H for 30% off (GovX discount code). That puts the 4800 at $1960, only $110 more than the 3900, which doesn't seem significant.
I dont know if it would be enough for you. Its a fill in for for content thay couldn't normally be there. Its not unnatural. It sounds better than dts x, which i found was a little in natural but used thr space well. I am messing around with my configuration and woll lwt you know. I was alos goijg to try out thr directional bass. I just dont know if I could reccomend a change based on that. I wanted to try out some more music listening. I just got some Steve Wilson stuff on my pc.How did you end up going with the Channel Expander?
I'm really curious how well this actually works. I'm on 5.1.4 (auro3d-style top-of- front and rear walls setup) with an x3600h, I want the auro3d upmixer & DIRAC ART in the x3800h, but if the channel expander is that much of a difference for ATMOS content (along with the other improvements) I might be swayed to fork out for the 3900.
My objective side agrees with you ... the 3900 is better value and better performance - on the other hand, the 4800 / 4900 has a beefier power supply - so at least in theory, it should have higher current capability, and should handle awkard low impedance loads more easily.... Hence I chose to spend the extra to step up to the X4 rather than the X3.The 125 W versus 105 W is less than 1 dB difference so not even 2 clicks (0.5 dB/click) on the volume dial.
Whether the difference in price justify that or not us up to you. To me it is a non issue, but that would be for my use case.
I would say the X3900H is clearly a better choice, mainly because of the far superior DAC, that may or may not result in able difference to everyone. There are a few features that the X4800H has and if those features are useful and important to you, the choice would be easy.
Agreed, in theory, there is no doubt the 4800 can supply more current, the point is only in terms of SPL in dB, and that humans need almost 1 dB to perceive a difference so your objective way to look at it is actually a practical way.My objective side agrees with you ... the 3900 is better value and better performance - on the other hand, the 4800 / 4900 has a beefier power supply - so at least in theory, it should have higher current capability, and should handle awkard low impedance loads more easily.... Hence I chose to spend the extra to step up to the X4 rather than the X3.
Performance of the X4800 has not disappointed... It is possible that the X3800 could have done the job just as well - but I wanted to play safe.
So it is not exclusively the "Made in Japan" thing (although that is nice)...
"The Reference Studio/60 v.3 is of above-average voltage sensitivity, at an estimated 89dB/2.83V/m. Its impedance doesn't drop below 4 ohms, and remains above 6 ohms for much of the audioband (fig.1), implying that it will work well with modestly specified amplifiers and receivers.
Agreed that only an increase to the 6800/Cinema 30 or up would give any palpable difference for a lot more money. If you're going to external amps anyway, the 3800 is the better option over the 4800 (even more so w/the superior SINAD on the 3900)! I'm not sure why the 4900 should even exist now that the SINAD has been solved for the new gen!Agreed, in theory, there is no doubt the 4800 can supply more current, the point is only in terms of SPL in dB, and that humans need almost 1 dB to perceive a difference so your objective way to look at it is actually a practical way.
When one wants to have more current to make an audible difference, one should look at amps that can output at least 2 dB more on all else being equal basis (that is, same speakers, placement, distortions, noise etc.).
That means, going from the rated 105 W to 125 W, the gain of 0.7 dB is not going to give noticeable difference in how the amp deals with low impedance loads, if you turn the volume down by 2 clicks when using the X3800H or X3900H, that's just fact that only the eyes/brains can dispute, not with the ears/brains combo Lol..
I don't want to get into debating this based on boundary/borderline conditions using "current", that's why I am sticking to the volume dial setting for comparison purposes, that is, accept an approximately, but conservatively 1 dB difference by lowering the volume 2 clicks on the Denon, you will only hear 1 dB lower spl when using the 3800. For such difference to be noticeable, one would be looking at the likes of the AVR-A1H, A10H or the Cinema 30.
So, my suggestions, based on electrical principles/theories, the practical reason for preferring the 4800, or 4900 would include (not limited to) the following:
Obvious features:
- 2 Ch stereo menu.
- 1 additional HDMI input.
- Larger, 2 line display
- 2 additional triggers.
- 1 additional zone.
Features that are there but not easily noticed even if AB comparisons are done on apples to apples basis:
- Monolithic power amplifiers layout, possible result in better separation (not shown in ASR measurements) and reliability (theoretical, logical, actually had more reports of amp failures on ASR forum).
- D.D.S.C.HD and AL32, supposed to enhance surround sound resolution/realism. Such benefits were described by Denon, but not verified by any known bench measurements.
- Lower specified THD+N, 0.05% vs 0.08%, this has been the way D+M (yes, Marantz equivalent models as well) for the past 10 years or more, never changed..
- Made in Japan, the benefits of this is probably more based on perceived better quality control that is based on historical practices and/or track records, in reality, with the advance in communications (QC/QS to international standards, internet, networking, synergy, standardization AI assistance etc..)
For me, I would always go with the 4000 series, and that would be the upcoming AVR-X4900H, not that I believe I could hear any difference but it is for peace of mind, knowing that the additional and/or unique features found on the 4000 series might just enhance sound quality in one way or another. Having said that, the 20 W higher output rating is the least of my concerns even if I don't use external power amps, though I absolutely do Lol. Note: If my choice is restricted to AVR-X3900H and AVR-X4800H, I would likely go with the 3900 if it costs unless the X4800H is discounted such as when it is considered "discontinues", that least, if lowered by 25% or more for reasons I gave before.
