Denon AVR-X3900H AVR Review
Rate this AVR:
    Votes: 10 4.3%
    Votes: 14 6.1%
    Votes: 147 63.6%
    Votes: 60 26.0%
What's the crack with the limited cross terms on the DnM models? now people have had time with the products does this really impact the overall effectiveness of Dirac Art?
You can't finish setup without it.
Well fuck that then. If I run into that during setup its going straight back to the store.
Great question that is tough to answer. People's hearing and contents they listen to, in terms of perception of minor differences, discernibility, etc., are not going to be the same in all cases. Frequency response is problem one of the most, if not the most impactful factor, what looks very different on paper such as the following, may still not sound very much different to some people.
If the black curve, that was Anthem ARC Genesis sounded to me as bad as I expected, I would have sold my AVM70, but I still has it. Though I am tempted to replace it with a X3900H in order to have Dirac Live bass control and ART.
Here's a second example that I got from my recent ART trial, two channels only:
On paper, ART, the red curve look much better, but in listening, the audible difference isn't that great, just subtly different/better to me. The ART spectrographs did look better as well.
So, whether the cross-term limit is limited to just below 100 for the AV10, per some AV10 users including @Oddball who use all available channels iirc, or not, how audible the differences would likely be dependent on other factors.
Also, the X3900H can only process 15 discrete channels vs the AV10, on all else being equal basis, the limit might be higher, logically speaking but you should email Denon or Marantz if you are interested in D+M devices and use ART.
Excellent post thanks! that really is quite fascinating and yes as you have had a chance to listen to the different results but with varying levels of effectiveness to your ears is very helpful. i really want an xlr connection so that rules out these cheaper models for me.
edit, you would have thought it would have corrected those dips around 130hz, even audyssey is giving you a better correction than ARC. What was the product you used for the audy/dirac calibration, they seem a lot better than ARC.
I agree with Peng - as usual. Even some bigger bumps in FQ response are difficult to ascertain when listening. I grew quite a bit of gray hair trying to iron that out pre ART - with Audy MultiEQ-X - but with limited success both in graphs and then even less in effect that is easily audible.
So while difficult question, the practical answer is that D&M's implementation is sufficient and sophisticated enough for most systems. Higher support levels in general yield better and tighter graphs, but I for one, could not really tell much audible difference as the ones I have set (and noted in the previous post) were more than sufficient. Usual caveat - YMMV, there is no universal answer.
I encourage members to go to ART thread to look for more detailed answers. Hundreds of members contributed to that thread and spend considerable time in doing that. That seems to be forgotten based on the number of basic questions that are popping up.
I use my desktop PC, tried both standalone and JRiver plugin, same results. ARC G cannot match performance of Audyssey with app but that's on paper only, so absolutely no offense to Anthem fans:), let alone Dirac. I suspect that could be one of the reasons we don't see much REW graphs posted on forums, most of the REW graphs posted are found on ASR, not AVSF.
Dirac made it very clear that they would not try aggressively "correct" those huge dips especially if they are narrow. ART often can do a much better job on those, hence the name "A" = Active.
Good showing from Denon.
My X-3400H is 100 years old :) ..May be time to replace before it dies on me ...
Was hesitant after reading about some issues it had with HDMI or eArc IIRC. Seem to have been resolved
Still a refurb X-3800 might be a better deal ... ALthough this one is better in most aspects but are these audible? Not sure
Thanks @amirm
My 3400H still going well. Being used for 2.1 tv duties and to stream Qobuz. I’ve recommended the x-3xx line to about 100 people over the years!
LOL personally can't imagine a less useful review than one of his
I often find his reviews, quite useful and informative.
He often gives a good rundown of the features of an item, why are they are important or not and why they might be useful or not, what it’s like, implementing the features, and living with and using the piece of gear.
When he has reviewed items that I’m familiar with I have found his reviews to be accurate to my own impressions.
Obviously, one’s mileage will vary.
(For instance … I recently finally bought a Kaleidescape Strato 4K player and I found Andrew’s review to be bang on in terms of the justification for owning such a player, the features and advantages of the Kscape system as well as the negatives , and what it’s like using the player on a daily basis)
I take it you don't use anything on the internet apart from this forum. Ever. Because I certainly need to give my email address for:
Every purchase online
Accessing my bank and pension
Accessing the NHS
Accessing every government service
Accessing every online media and TV service
Registering every guarantee on every product I buy
Managing every license for my music software
Registering to vote
Managing every subscription to anything.
And, as lots of people have stated, you don't need a HEOS account if you are not going to use any network functions, if you use network functions then, just like every other service on the planet, you need an account in order to personalise the service. It's just an email address, it really doesn't matter.
No you don't need to give email ID to use a webserver at home. Your internet box, your printer, whatever. It can exist without grabbing data, as much as LG tv's don't need to harvest and exfiltrate device ID, watching habits, local Wifi SSID's, and whatever else they can.
They do it because people like you blindly accept it, buy into the hogwash, and perpetuate the 'personalisation' nonsense.
I think you're confused about what is mandatory and what is contractual. Apart from blindly accepting surveillance is their right rather than something which is permitted or derogated.
What surveillance? Possession of my email address, as is used, for example, by this very site we are using, doesn't constitute surveillance, it's no different from a phone number or address, which are generally publicly available data. Are you suggesting that everyone who has my email address is surveilling me? Dozens of organisations have my email address, so that they can communicate with me, the exact purpose of an email address. Do companies I shop with keep a record of my purchases, almost certainly, especially if I register a guarantee with them, that also isn't surveillance, it's ensuring my legal rights. And quite what it has to do with accessing ones own personal devices on ones own network is a mystery.
Indeed. Many of these 'features' that compromise our privacy are actually government-mandated. Sometimes these side effects are unintended and sometimes intended. First and foremost on your mind should always be the fact that governments are happy to let corporations be the data skimmers that can be subpoenaed later so the governments themselves do not have to be the 'bad' guys.
That sounds rather like a predominantly US problem. Not entirely sure what any government would do with knowing that I own an AV amplifier, persecute me for not being deaf/blind?
Did you try setting it up without connecting to a network at all? Several folks have said they own this gear and have successfully set it up without creating an account. Try a factory reset and rerun the setup without network, after all there are people who don't have internet connections, so unless it's explicitly stated that the product requires the internet to function then it must be possible.
I think the point they are making is more about the implication. Who knows if Denon is scanning your network, or otherwise using the device to do surveillance of the network it is connected to. Collecting your email is certainly an identifier that may attach to anything else they collect.
That is worth worrying about these days, especially since we know how much of a data hoover certain TV brands have become.
To be honest many of our devices are using surveillance on the home network. I dont want to go off topic because I want to know more about the 3900 but the recent exposure of the LG OLED TV data collection is eye opening.
That is a preposterous suggestion. Firstly security software would instantly pick up the scanning, secondly they would be outed within minutes of the first box being deployed and finally it would have absolutely zero value to them. Who on earth cares what devices are on my or your networks? Oooh look, 4 lightbulbs a tumble dryer and 2 kindles. Seriously, your supermarket knows far more useful information about you, unless you only use cash, something I haven't needed for at least a decade. This 'surveillance' panic is blown out of all proportion, no one has the resources to monitor all this data, especially when it has little to no value, it's far easier to profile you from your shopping habits, banking transactions, employment history, magazine and newspaper subscriptions, TV channels subscriptions, sports teams supported, etc. etc. The presence of a dozen smart plugs in your home is of utter insignificance compared to data that is readily available.
Yeah, it's like how some people refuse to register for facial recognition at the airport even though they're recorded by about 1,000 CCTVs every time they fly lol
FFS, the HEOS account is not REQUIRED/FORCED, several of us are using the x3900h without an account (even with a network/internet connection). :facepalm:
Can we please move on and discuss the product.
EDIT - I have been using my x3900h for almost two months, it's on most days, and I have not had a single notification/pop-up asking me to create a HEOS account.
- Jason
