Denon AVR-X3900H AVR Review
Rate this AVR:
    Votes: 10 4.4%
    Votes: 14 6.1%
    Votes: 146 63.8%
    Votes: 59 25.8%
This is a review and detailed measurements of the Denon AVR-X3900H 9.4 4K/8K Dolby Atmos AV Receiver. It was kindly drop shipped to me by a member and costs US $1,849.
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos DAC streaming review.jpg
It might be my imagination but the front panel looks a bit more modern. And the volume control no longer a stiff knob. It looks like you can drop down that front panel but it doesn't do so. Sadly, I could not figure out how to go through without the start-up sequency. :( There was no "OK" button that I could find.
Speaking of start-up, after a few steps, it demanded that I setup a HEOS account or it would not continue! What the heck??? In the past this was advisory at the end but now it is in the middle of setup. Many people don't use AVRs for streaming so have no interest in such functionality.
I was pleased that there was a web interface which made interacting with the unit easy although I could not find access to Pure button so had to use the remote.
Everything worked well other than static that flickered when I selected CD analog input which naturally has no video. Why not have the option of some animation or slide show Denon?
Firmware was upgraded through HEOS app but seemingly, it decided to reboot later when I tried to soft power cycle the unit. It then took a long time to start.
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos DAC streaming back panel HDMI...jpg
Denon AVR-X3900H AVR DAC Performance Measurement
Nice to see continued support to turn off the amps so as to use the pre-out without the unit reducing performance. With the amp off, the results were quite respectable for the category:
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos DAC Measurement.png
You do have much more output voltage if you need it but comes at a penalty:
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos DAC distortion and noise vs i...png
Gain matching will be a bit tricky seeing how there is interaction on where you set the volume control. Sweet spot is around 1.5 volt if that is also the optimal value for your power amp.
Above test digitally sweeps the input. Users would use the volume control so here is that:
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos DAC Volume Position vs Output...png
Ignore the time scale -- that is how long it took me to turn the volume control 30 dB. Read the performance on the left on the blue line, and output voltage on the dashed red.
This is a few notches above my old favorite, AVR-X3600. Noise performance is really good, clearing 16 bit hurdle easily:
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos DAC DNR Measurement.png
Multitone was again respectable:
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos DAC Multitone Measurement.png
As was IMD although we see that we are still far from desktop budget level class DAC:
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos DAC IMD vs level distortion M...png
Jitter showed fair bit of low level messiness:
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos DAC Jitter Measurement.png
Frequency response was fine:
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos DAC Frequency response Measur...png
I saw no filter selection in my quick look but what is there is again, fine:
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos DAC filter Measurement.png
I was disappointed that wideband noise+distortion is not beating our ancient $99 DAC reference:
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos DAC thd vs frequency Measurem...png
Linearity is again, good for the class:
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos DAC linearity Measurement.png
Denon AVR-X3900H Amplifier Measurements
I dialed the volume back a bit to get nominal 25 dB gain:
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos Amplifier HDMI In Measurement.png
Switching to analog, we take a slight hit, as we should:
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos Amplifier CD Analog In Measur...png
Going by eyeball average of the two, the amplifier is very good for the class:
To make comparisons easier, I stayed with analog input for the rest of the testing. I did have Pure Direct on as otherwise, there is a penalty for signal processing:
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos Amplifier CD Analog In Freque...png
Looks like ADC sampling is 96 kHz which is quite a step up from typical 44.1/48 kHz given that gentle slope down in green. Low frequency rise is from the default crossover selection. I wish the level was calibrated so that the two graphs match. As is, there is half a dB mismatch.
Noise as you guessed it, is again very good for the category:
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos Amplifier CD Analog In SNR Me...png
Multitone and 19+20 intermodulation measurements turned in good results as well:
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos Amplifier CD Analog In Multit...png
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos Amplifier CD Analog In 19 20 ...png
Power levels are unchanged but overall, the 3900 is more quiet:
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos Amplifier CD Analog In Power ...png
Seeing how I am only driving 2 channels, we have far more on tap during quick bursts:
And it doesn't give up much at 40 Hz:
Power sweeps at different frequencies shows typical, well behaved class AB performance:
AVR-X3900H 9.2 Home Theater Surroung AVR AV Receiver Dolby Atmos Amplifier CD Analog In power ...png
You are noise limited at frequencies at or below 1 kHz. Then the loop gain bandwidth becomes insufficient and distortion starts to dominate fairly early (1 to 2 watts).
The AVR-X3900H seems like a mid-cycle turn up to use a car analogy. It seems to be more refined in every area without any of the regressions we have seen in past iterations. Really, other than some noise and inference in jitter, there is nothing that hurts the eye. Seeing how the brand has been my favorite in AVR class, this is all good news. Glad Denon has not put aside their Audio Precision analyzer! :) This would be the mid priced AVR I would buy if I needed one.
I am going to recommend the Denon AVR-X3900H.
Thanks Amir, great stuff as usual. Needs a pic of the back panel connections though.
Teardown
See attached file
Mandatory account = no buy list (for me at least). I think this would not be even legal in the EU, might be wrong though.
Amir,
Thank you for confirming a 'return to form' for Denon's '3xxx' AVR.
Great performance for an AVR. Thanks for the excellent review.
great showing
Thanks Amir, I think a lot of people have been looking forwards to this gratifyingly thorough test.
One question though - was the power amp SNR test done at 5W output?
Do we know what DAC chip this one is using? I recall that was topical after that plant fire, think it was for the x3600?
Wow, I kept waiting for the other shoe to drop but this made it all the way thorough without slipping up! So rare in an AVR. And quite affordable given all that you get.
Mandatory account is lame, but I'll accept this tiny amount of enshittification. It's not like I haven't been using burner emails and strange personages born January 1st, 1901 for the past 30 years.
Yes, they always are for amplifiers. I thought the label said this but I see that it did not. Will fix for the future.
Oh, I was doing just great with this one until I read about the "mandatory account" which is, of course, nothing but a blatant attempt to commoditize the user and sell their data with maybe some tracking software (a la LG) thrown in. Obviously, shite like this is in no way needed to run an AV receiver, which have quite literally been out there for five decades without "user accounts". Yeah, there ought to be a law, bless the EU's collective heart if it's promulgated one. As for the US, we all know the utter impossibility of something like that happening in our current environment.
Great review, Amir. Too bad it's a no go for me and some others. LG won't be getting my repeat business either.
