The clipping myth just doesn’t die for preamp mode. I can’t even count how often you had to explain this in various threads. Thx.
I can also confirm, yes the SINAD is highest with ca 100dB at 1.4V and then slightly drops by ca 5dB all the way to 4Vrms. Yes my x3700 easily puts out 4Vrms in pre amp mode only (measured it myself).
Would I like the SiNAD to stay at 100 yes but the drop to ca 95dB isn’t clipping.
The only person who can put this to rest is Amir, I tried but failed. He stuck to his gun, defining "clip" as when SINAD starts to drop precipitously. He is technically not incorrect but practically speaking we should not define clipping that way because "drop precipitously" is relative. What seems like a steep slop can look flatter simply by changing the x axis scale.
Actually, in the following example, not for you but for @Beershaun who should be able to understand my point more easily using this example:
Here Amir said it was nice, "Doesn't clip until 4.2 volts":
Think about the following facts:
1) Marantz NR1510/slimline series do not have preamp mode, no HDAMs either, so why it is not "clip" at 4.2 V instead of 1.4 V?
2) See that the Red curve dropped "precipitously" at about 1.0 V to about 76 dB SINAD just like those Denon AVR did at about 2.0 V in non preamp mode, why?
3) Now take a look of the xy axis scale he use!!
4) Now look back on the Denon AVR's SINAD vs Output V graph, and notice that if Amir had done the same measurement but to 5 V like he did on the NR1510, you can see that at about 2 V, the SINAD vs V slope would become much gentler and may even level off like it did on the NR1210. There is no reason why it would behave differently, considering the parts and circuitry of D+M's AVRs basically have the same preamp/dac block diagram.
I don't have one for the 1510 but here's the one for the 1508, that's the same for other Marantz/Denon AVRs except the NR series and Denon don't have HDAMs in the signal path:
Same dac and volume chip for the preamp/dac blocks! So again, why would the NR1510 "clip at 4.2 V, while its bigger brothers "clip" at 1.4 V? Answer: It's Amir's choice, he's the boss, I can only voice my opinion.
