Hi
@sask15 ,
Thanks for the update, the release date is good news. The DAC change was wishful on my part. Not sure if there can be an improvement in performance with the 4800 over the 4700 or 3800, but it has a couple of features that can be beneficial. I am married to the 4 sub outs capability and the Dirac upgrade. Hoping the Jitter Chip and
Monolith Amp construction/
larger PS offer improvements.
In models below the X8500H and the upcoming A1H spending more delivers very little more in the amplifier muscle category or preamp quality. Selection between these models should likely be done based on features. Price is also important; most people
believe they are getting a better product when they pay more.
X3800H - Transformer - 9.2 lbs.
X4800H - Transformer - 10.8 lbs.
X6700H - Transformer - 11.7 lbs. - Little meaningful difference between models - except in price
X8500HA - Transformer - 17.6 lbs. - More like it.
A1H - Transformer - 24.5 lbs. - Now that's a transformer at least in AVR land.
X3800H - Amp. power supply capacitance - 12,000 uF
X4800H - Amp. power supply capacitance - 15,000 uF
X6700H - Amp. power supply capacitance - 15,000 uF - Again, little meaningful difference between models - except in price
X8500HA - Amp. power supply capacitance - 22,000 uF - More like it.
A1H - Amp. power supply capacitance - 33,000 uF - More like it, but still far from that found in separate power amplifiers
Monolithic power amplifiers - one board per channel - Typically worse performance
In ASR measurements the monolithic amplifiers have worse measurements than the single board amplifiers. Also note; the monolithic board amplifiers circuit design and board layout are the same in all of the models that use them. This is from cheapest to highest cost Denon and Marantz AVR's.
In almost all ASR and Audioholic measurements typically at least one monolithic board from a pair or set, offers worse performance than the others, that is, production quality is evidently inconsistent.
Heat dissipation from monolithic boards (power transistors) into the heat sink is also more uneven than in single board power amplifiers due to the location of the power transistors on the heat sink vs. the heat sink fins.
The monolithic amplifier boards are found in more expensive AVR's so once again there is the advantage, clearly felt by many, that the boards effectively cost more!
