Denon AVR-X3800H Review
Rate this AVR
    Votes: 89 17.2%
    Votes: 226 43.6%
    Votes: 157 30.3%
    Votes: 46 8.9%
Direct and Pure Direct bypass and disable all EQ/Tone, Audyssey, surround mode matrix (eg., turning Stereo into Dolby Digital or Multi-Channel Stereo), etc. It also bypasses Bass Management, so speakers are set to Large and no crossover to a subwoofer sending bass from 2-channel stereo to turn it to 2.1 -- only native LFE channel signal froom surround sound content is sent to the subwoofer.
Pure Direct also turns off the front panel display screen and analog video circuits (digital video / HDMI still functions).
From my 3700h manual for Pure Direct:
  • The following circuits are stopped in order to further improve sound quality.
  • Display indicator circuit of the main body (display will go off.)
  • The analog video input/output switcher and processor is disabled.
You can also use the sub in direct mode with some Denons. Listening to a 2ch source now with subs in direct on a 4700. There's a mode to setup 2ch listening, where you can still select LFE and use crossover (and set distance/level for speakers, too). Works in stereo or direct.
Just to add another Direct/Pure Direct use case, if subwoofer out is set to "LFE+Mains" and playing PCM 2.0 source, the subwoofer will activate so 2.1 output.
FWIW in such case the sub will be limited by the crossover set.
Yes, like the condition where the sub can play 2.1 with 2.0 input in direct/pure mode, this is also spelled out in the OM.
How bad is this AVR to the current market? Is the SINAD values really audible or just bad for this level of equipment? I have a s930h now and I found a x3800h for 1400 CAD, the 3900 is 2500 CAD. I almost pulled the trigger but after finding this review I'm hesitant. Not many others things are in this price range unfortunately.
Crazy how prices have gone up. Is the 3800 a refurb from Denon? So many factors very difficult to say if the two will be distinguishable in blind listening tests. Never with my 3800 do I question the sound quality but I have no direct reference. If the 3800 is used, has no warranty, and will leave you wondering save up for the 3900 and wait for a sale.
It's B-stock and comes with a 1y warranty and 30 day exchange. The price is hard to pass by. My S930H was B-stock too and been running for 8 years.
It's wild how much prices went up and on top we get shafted in Canada for all this.
I doubt I would perceive a difference in sound quality between a Denon '3800' and a '3900'.
The difference in price can defray the cost of adding Dirac software to a 3800 - which has been discounted 30 percent in recent Novembers.
I too have had few issues with a refurbished AVR - but they are complex. Years after acquiring one, I discovered a channel of an analog input produced no sound.
Consider checking all the inputs and outputs of any refurbished AVR.
It's not audible. What is definately audible is the price difference between the 3800 vs 3900 used for buying Dirac ART or a good subwoofer. In your case I would make sure the B stock item is not refurbished or damaged, but open box or sent back by a customer and has full warrenty.
It's maybe borderline and worth discussing on paper, but in reality I couldn't hear anything ever. And I'm constantly trying pretty hard / loud.
With such a huge price difference I would take the X3800H over the new model again.
Almost certainly not audible. I would take that deal and add Dirac ART
Or add some nice little poweramps like the 3e A5/A7 and put the Denon into pre-amp mode with internal amps off.
As an adjunct/alternative to DIRAC, I would also consider GSonic Immersive + Evo32 from ObsessiveCompulsiveAudiophile, as another option for audio room correction. $150 for the two software products (both are needed and work together), and the license is not locked to a single AVR. (Should you have multiple Audyssey AVRs, now or in the future, the same software will work for all). A UMIK mic is not needed, but probably useful (and required for DIRAC).
I have Audyssey MultEQ-X and DIRAC full band for my x3800h. I think the above product is superior to Audyssey and similar to my DIRAC full bandwidth corrections. I cannot comment on ART or whether it is 4x a better audio experience than Evo32 for 4x the price.
There are plenty of free options that achieve what ART can do. It comes down to plug and play vs a more manual approach. ART has given the community a plug and play option that is slightly less expensive as compared to an OEM like Trinnov. Any real effort given to the manual approach should reveal the same results as to ART or Waveforming
Yes, OCA's past options have been free, but used to be more intensive in terms of manual data collection and processing. For a motivated enthusiast, they were not particularly difficult. In my limited hands/knowledge, I couldn't quite get Audyssey or prior OCA products to sound as good as the DIRAC calibration.
The more recent products I mention have reached a point, in my opinion, where they are akin to Audyssey or DIRAC in terms of ease of use. Our individual obsessions with measurement technique, etc, will remain the same for any product.
I bought mine in 2022. The only issue I had with my 3800H was the remote, the one volume button stopped working. I found one on Amazon that has worked fine.
I almost thought my refurb X3800h had an on-board amp issue last month (all of the speaker outs stopped working, but all preamp outs were fine) - but it was just a speaker wire with a segment of missing insulation that shorted when I was moving/connecting additional sub RCA's. I factory reset it, and re-seated all HDMI's (found 2 half-seated!) and it still wasn't working before I found the speaker wire issue. Now, all is well after a few days of uncertainty and potential dread of shelling out $$$$ for an X3900h. I'll be adding ART and keeping the X3800h for sure!
SINAD chasers will undoubtedly find a reason to upgrade from 3800h to 3900h (oooh - look those SINAD specs on paper! lol) - my "reason" (a potentially blown amp section in my 3800h) was luckily proven to be a non-reason :) So the 3800h remains doing all I could ask of it to do w/o another $1500 bill + DIRAC license for a few dB's of SINAD I'll never hear. :cool:
I will say - the refurb remote had tape residue on it. But otherwise no regrets on the refurb purchase and savings!
Choose on feature set, warranty, price....you're not going to hear a difference in SINAD between models. I have several older Denons, no worries there either in that regard. The newer ones have some better feature sets (like 4 sub capability, dirac, things like that).
