Well, my 3800 arrived yesterday. At 20% off it still felt like I was overpaying (given the price history over the past 4 years) but I couldn't take it anymore. I had to get
something into the house (
we've been without a functional AVR for almost 2 months).
Had a bit of a funny moment when I could not for the life of me get it to do anything Dolby Surround'esque (ie Pro-Logic type decoding) on 2 channel material from the AppleTV (via HDMI). Only choices seemed to be Stereo and Multi-Channel Stereo (which soooooo dont work for soundtracks). Then I figured out the Apple TV defaults of
Atmos:On, and
Continuous Audio Connection:On produces a wrapper the Denon does not want to further process. By changing those I suddenly got
Dolby Surround options. Whew! We watch a LOT of 2 channel movies. lol
I do find it odd that some settings are obfuscated unless an affected format is
allready playing. Maybe someone at Denon thought this make things less overwhelming for neophytes but this thing, good or bad, is priced squarly in enthousiast teritory.
Power seems
ok. I'm driving a mix of 4ohm/91dB and 8ohm/85dB speakers (all high passed) in a small room and it seemed to have no issue even up arround -10dB reference. Got quite warm, but not uncomfortable to touch.
Why oh why Denon did you think it was a good idea to use a
KC Daylighter for the power LED?!? Honestly, even with two layers of tape over it its still too bright!
It should dim at the same rate as the front panel display.
Tonight's project: Audyssey....
