Well there was no misunderstanding…i assumed the 3800h should be around 50w/ch 5-7ch+ driven. Which is the same for my yamaha (although it is 150w/ch into 2ch, and 50w/ch into 7ch+, as far as the reviews state for pretty much every yamaha aventage lineup)
Then it is in fact a case of misunderstanding on the following:
- You started talking about Yamaha, so naturally unless you make it clear later that it was the Denon 3800, I would think that when you suddenly mentioned 50 W, you would stil be referring to the Yamaha 3080 that you started on. Yes you did mention the 3800 too in a later post but your original question was about the 3080
Your post#3010:
Coming from a yamaha a3080, will i notice a downgrade in sound…? Any idea
- You might have misunderstood Denon's 5-7 ch rated outputs. It has never said anything about 50 W/ch with 5-7 ch+ driven. You can however, read the reviews where Amir did measure Denon AVRs (selected models only) such as the following, on the X3700H that has the same power supply and power amps as the X3800H:
Here you say 100 W, not 50 W, but at 1% THD+N, as I mentioned, use conditions has to be considered, for example, if you raise the bar to 0.1% THD+N then you would get a little less output.
- It is not very useful to use the 100 W rated output because a) that's only the case if the amp is delivering the exact same outputs to all channels simultaneously, that is practically speaking not likely in real world applications.
- And, that 100 W/Ch is for 8 ohm resistive load, if a 4 ohm resistor test load is used, the numbers will change, likely higher on short term, but much lower on longer term, say if for longer than a few seconds.
So yes there are misunderstanding, in this case not only between our back an forth posts, but also on the interpretation of the output power based on different conditions. It seems that you are not open to clarifying points made in multiple posts so I am not going to continue, and would just move on and back to my little corner in my HT room.
