- Joined
- May 21, 2021
- Messages
- 435
- Likes
- 297
I will plug in my 3800 tomorrow and check the menu. I should have done it earlier.
Most welcome. It's pretty much the same process for 2.2, you just need to make less measurements. It's worth to check the video once in order to understand the basics of it, though it really is a quite simple and fast process. Can't comment on .2 calibration as I only have one sub, though I have read very very good comments on multiple sub integration, and some people actually combine it with minidsp. It is also recommended to use REW's latest beta. Also, after you have your measurements done, it's fairly easy to test different EQ target curves and repeat the process with updated versions of Nexus, which takes around 5 minutes to process. I believe OCA is also working on an updated process for calibration, though I don't much about it. Good luck finding a nice price for it!Thank you so much for the detailed description. I will start watching/reading so I'll be ready if and when I get my AVR-X3800H, timing would depend on when it will drop to, or close enough to the US sales price point. Hopefull it will happen on boxing day.I will use the unit for 2 channel stereo music only but it is good to know @OCA has got us covered on everything, even for using Atmos sweeps, though I would like to see one for 2.2 stereo if there is such simplified version and therefore a shorter video to watch lol... I could do wonder with Ratbuddyssey, but OCA's scripts seem like a much easier and quicker way to get great results. Either way, it really renders my 2X4 HD useless, but I will keep it until I played with the X3800H, then I'll sell it for sure, even for $100 or less, is better than having it sitting in the box, though now that I have sold the X1800H, I had to take it out of the box and used again mainly to set crossovers when using my separates that are 2 ch stereo only.
I would expect that.There appears to be no Dirac bass management or possibly no Dirac correction at all when playing thru Heos. Can anyone confirm this?
It's the speakers connected to the x3800 that have that have no correction or bass management when using Heos. The Denon is the only Heos client. So, eg, if I play Spotify thru the x3800 to my bass managed LR, I get no sub or correction.I would expect that.
Bear in mind your DIRAC measurements set up correction filters specifically for the speakers and room you measured. Playing via heos to different speakers in a different room, then applying those filters does not make sense, and may actually sound worse.
HEOS is, unfortunately, total crap.It's the speakers connected to the x3800 that have that have no correction or bass management when using Heos. The Denon is the only Heos client. So, eg, if I play Spotify thru the x3800 to my bass managed LR, I get no sub or correction.
Sounds like you can't through HEOS. Maybe through AirPlay 2 (lossy AAC 256kbps)? Alternatively, you could use a dedicated streamer like a Bluesound Node or an NVIDIA Shield TV Pro running the Tidal app (which will give you DD+ Atmos over HDMI).Wait I can’t use like tidal with heos and my 2.2 system?i mean with dirac bass control
I've tried Spotify and DLNA, neither used Dirac bass management or bass controlWait I can’t use like tidal with heos and my 2.2 system?i mean with dirac bass control
Well then, I agree, that is crap.It's the speakers connected to the x3800 that have that have no correction or bass management when using Heos. The Denon is the only Heos client. So, eg, if I play Spotify thru the x3800 to my bass managed LR, I get no sub or correction.
Damn. That is not good , but can you use base Dirac in stereo then?I've tried Spotify and DLNA, neither used Dirac bass management or bass control
If I add an SMSL DO-100 and connect it via HDMI
Hi! Im new here and i just bought a denon 3800h av received from amazon us it has 100v, and in my country the power voltaje is 220v. I was planinning to get a tiroidal power up step down converter in order to use it. If there any other way to use ir without The voltaje regulator !? Like changing something inside ? Thanks 100v to 220v step up converter.
It should be step down converter, right? 220V network to 120v AVR.Try to find a quality made in Europe or Japan step up converter.
Also a Denon 3800 owner but I only have Dirac Live Full Bandwidth license (no DLBC). Here are some answers and beginner tips:Hello everyone,
I’m still a beginner. Currently, I’m using a Denon X3800H AV receiver with an SVS SB3000 subwoofer, and my 5.1.2ch setup consists of SVS Prime Satellite speakers x5 and 2 Monolith THX campact satellites.
Previously, I used Audyssey XT32 for room calibration (with two Speaker Presets saved). However, since Dirac started their Black Friday sale yesterday, I’ve purchased Dirac Live Room Correction + Bass Control. I have a few questions I’d like to ask:
If you have any related articles, videos, or materials for reference, I’d greatly appreciate it. Thank you!
- Before running Dirac, do I need to disable Audyssey or reset the two Speaker Presets saved on my receiver to their default settings? If there are any other feature I need to disable or reset, please let me know.
- Should I use the advanced subwoofer tuning features in the SVS App (e.g., PEQ) before running Dirac, or should I let Dirac RC + BC handle all speaker and subwoofer configurations?
Yes, step down.It should be step down converter, right? 220V network to 120v AVR.
I would rather look for autotransformer than electronic converter. I don't know how good are available converters, but they usually aproximate sinus voltage at output, which can lead to noise or additional heat on AVR.
Other thing is network frequency. Switching from 60Hz design to 50Hz network overtaxes transformer. I would try to lower voltage even more, like to 100V.
Or maybe there exist a good converter to 120V/60Hz?
