What have people's experiences been with using the Multi EQ/Dynamic EQ/Dynamic volume? I've experimented a little and found:
1.You don't have to turn the volume as high to get the same 'loudness' compared to having these features turned off, in fact 0-30 on the absolute scale is no longer redundant and actually produces audible sound.
2.It sounds more immersive, especially on the D'Surround setting (although speech sometimes sounds likes its coming from surrounds as well as center speaker)
3.Some higher frequency sounds can sound a little harsher
4.I can't hear any real difference between setting the compression settings to light, medium or Heavy (isn't less/no compression technically better as it gives 'lossless' audio?)
5.Using a decibel meter, the readings don't jump around as much, its more stable
6.When you turn the volume up past about 50 on the absolute scale, there seems to be 'diminishing returns' when it comes to overall loudness, whereas, with these features turned off, it takes a smaller increase in the volume setting to get a noticeable increase in loudness.
Just my subjective experience, what are your thoughts? Is there a 'right' approach to these settings or is it purely personal preference?
