Last week I had some things come up which needed my attention, but I'm free now. For those interested in the measurements I'll be doing of the new 3700 (v2) with substituted DAC, and the first generation 3700 (v1), I'm starting tonight! Installing the software and doing some testing. Yes, v1 has already been measured here. With both receivers done by me, both will be hooked up the same way, in the same place, at the same time, and with the same stuff - eliminating many potential errors. It's better for comparison.
About the listening tests, I can now switch between both receivers in about 0.5 seconds. I have two 2 pole 2 throw 120V/20A switches. I wanted a 4 pole (to switch both speakers with just one flick), and I would have got one if one was available like I was told. But it wasn't so I didn't...
Fortunately it's still relatively easy to switch between receivers while having to use two switches:
A toe is used to press the space bar while both switches are flipped at once. The space bar selects "apply" in foobar2000s "preferences" window, effectively changing the "output device" (which is preselected by the operator), with each switch connecting one speaker to the same channel of the other receiver. The operator has the hassle of selecting the other receiver in a drop down menu before switching can occur, but that's life.
On page 70/71 are where all of my posts about testing v1 and v2 are. I've outlined which tests I plan to do. Read them and if anyone wants any other tests done, let me know. To know my limits, the interface I have/will be using for these measurements is an RME Babyface Pro (non-fs version). I can do two channel full power tests at 6 and 4 ohms now, with resistors. And full power tests through 8 ohm two way sealed box speakers with tones above 150hz (short term ~5 seconds above 2khz). Important note, I must return v1 by September 15th, so the sooner, the better!!
Edit: about the listening tests, it's unfortunate that a switch has to be in between the 3700 and the speakers, but it shouldn't affect the comparison. The switches are brand new and clean, and rated for 20 amps. The effect it has on the sound will be will be very, very small, and both receivers will be affected the same way and the same amount. Since I'm comparing the receivers, the differences should still be the same. We'll compare with and without switches to be sure
