Ah, reading it more carefully the graph was supplied by Sound United (denon), is there anything similar for the 3700H?If I understood correctly Audioholics did not measure the 3600 and the graph was from Denon, not Audioholics.
At this installation, there is no AC here and it has been hot (upper 80's indoors).
Preamp mode gets hot in my cabinet that has limited airflow due to the fixed shelf height and glass doors.
The unit is hottest on the center-left top. I have moved the fan blowing out (for now) to limit dust and it has reduced temperature.
I suspect the amps are disconnected but remain powered up and there are other significant heat sources.
View attachment 76426View attachment 76427View attachment 76428
- Rich
Please sweep the preout up to 4V or clipping with the amp disconnected. I bought one and want to keep by AHB2 on the 4V gain mode.FYI, I am packing and shipping this unit today so that I can get on with other testing. And the owner can have it back to enjoy.
It's worth it!You are killing me. I already packed the darn thing....
OK, here it is:It's worth it!
BTW, their measurements may be with analog input where they have flexibility to set the input level and get around gain staging issue I talked about. I am using digital input where the DAC inside determines the levels so no flexibility. This of course is the primary usage scenario than using analog input.Please sweep the preout up to 4V or clipping with the amp disconnected. I bought one and want to keep by AHB2 on the 4V gain mode.
Please see this graph from the 3600h
much appreciated!OK, here it is:
Notice that I have to turn the volume up to 89 or you won't get 4 volt output. Once there, the AVR switches gain stages causing performance to drop across the board. In addition, as the graph says, you can't go to 4 volts. Max usable is 3.73 volts.
I bought the 3700H open box from my dealer. Unfortunately, the MIC box was empty so that options is out for this year since my vacation ends soon. A new MIC is being mailed but probably not in time.
- Rich
That may cause clipping in digital domain and cause some kind of compression or worse. So I would not go there.Question for who may know : would it be the same output level with VOL at 89 and let’s say VOL at 82 and channel trim level at +7 dB ?
They are all the same.I trip over my Mic cord and broke the connector. They actually send you a different mic so I question whether the replacement mic is calibrated to your receiver.
Any chance to push the LR preouts to 4V with the amp disconnected? Audioholics did this with the 3600H and the results were pretty good. Wondering if the 3700H is good at 4V as well.
https://www.audioholics.com/av-receiver-reviews/denon-avr-x3600h
Just to reinforce a point...
Denon provided this graph with no details of how these measurements were made. Why are you claiming that Audioholics made these measurements?
Not directly related, but this also answers to my previous question, and I believe @Anterantz 's as well, about if/why the unit does not run cooler in preamp mode.
Pity. IIRC, the older Pioneer Class D AVR's I used in a previous job testing streamer boxes, you could shut off amps individually. Denon needs to get to that in the next gen. Back to looking at seperates again.
