Benchmark provides power into load numbers, maximum amps, and voltage gain, though not into phase angles.
The maximum voltage gain is interesting because that can be the limiting factor where the impedance is very high.
The Revel F228Bes are rated at 90 dB efficiency but have impedance that dips below 4 Ohms at 100 Hz and 12 Ohms at 2 kHz.
In one area an amp could run out of current and in the mid-range, run out of voltage.
If looking at WPC at 8 Ohms, an AVR could be over 100 WPC and so would the AHB2.
At 4 Ohms, the AHB2 almost doubles to 180 WPC whereas the AVR will drop (as in your example) to 60 WPC.
The immediate results is reduced bass. With the F228Be that would mean a drop in output between 80 and 200 Hz.
The ASR measurements seem better at low volume than those found in Sound and Vision.
- Rich
You are right! Benchmark's AHB2 specifications are the best I have seen, but I might have missed some obviously.
The info they provided does allow me to calculate the rated current under each condition they specified, except as you mentioned, they still ignore the important phase angle part that could be an important factor for certain speakers.
Other than that, the only thing wrong is just technical, that as I mentioned before it is incorrect to use the term "watt" for any load other than resistors.
One thing they can do though, is to provide the "duration" for the rated current (actually "power", the way they are doing it).
That's because we both know those numbers are not really for "continuous" in literal sense.
I am not saying there is practical value in a real "continuous" rating that some super expensive gear are rated for, such as certain models of the likes of Krell, Bryston and may be McIntosh etc., not for most home users anyway. Just that it would be great to see rating such as:
100 W, 8 Ohm load, 60 minutes minimum, at room temperature, adequately ventilated per manufacturer's recommendations (this is sort of cya..)
190 W, 4 Ohm load, 30 minutes minimum...............................................................................................................................................................................................................
With a warning note: For <8 Ohm speakers with average phase angle >35 degrees in the range 20-300 Hz, reduce duration by 50%, that's just an arbitrary example.
Such additional information will likely be useless for a lot of people, but for a $3,000 100 W amp I think they worth it to people who truly care about specifications.
