Can you a new thread? Happy to provide more ideas but don't want to pollute this x3600h threadThank you for your response!
The room is built according to a drawing by a renowned acoustician and has been qualified buy him.
I’m sensitive to when the sound is off. In the beginning (before the addition of the Denon x3600h) I had some issues with the bass in the room, nothing serious but to me it was not right. After some measurements I found that there were some modes at 31 and 68 Hz as in the picture below.
I had those corrected using a DSPeaker anti mode dual 2.0. I also bought a professional frequency crossover control.
After that everything has been running perfectly.
I was very happy with the sound and wanted to add Atmos speakers.
I never dreamed that there would be such a difference. I still believe that there must be a switch that I have forgotten to turn off, or on.
I have used the Oppo 103 as the source of 7.1 decoder and just running through the signals on the analog HK Signature 1.0. I used 2 HK Signature amps 2x5 channels. Passive subwoofes and fronts run on one amp the rest on the second amp.
Speaker setup in the studio.View attachment 63389
Following images are from my ipad on the current setup measurements with Denon x3600h and the Audyssey App. The frequency range is set to work from 0-500Hz. I have made no compensations except on the Subwoofer where I have raised the bass with 10dB, see image.
View attachment 63390View attachment 63391View attachment 63398
View attachment 63392View attachment 63393
View attachment 63394View attachment 63395
View attachment 63396View attachment 63397
Jannewq,Thank you for your response!
I don't think that is going to be the fix you need, however. There are a couple of other issues I see.Thank you! I will try this.
I'm not aware of any way to use an onboard amp for the subs? Can I assume you mean one amp for each of the front and center speakers and not one amp to power all three speakers? Sorry, just trying to interpret what you are saying. So..... what are you powering with your external amplifiers? Can I also assume you mean that you are using the subwoofer pre-outs for external amplifiers to power your subs?Neither the Dspeaker nor the external crossover is connected. Only the Denon, 1 amp for fronts, subs and center. I did encounter some problems in the beginning with Audyssey because it's sensitiv to gain on the bass. The 200Hz crossover is a recommendation a got and tried. I'm going to re-run the Audyssey with even lower gain setting.
Is it possible to get the audyssey to do only the bass?
Yes, from the Audyssey MultiEQ App. In the attached screenshots you can see I’ve limited my Audyssey to 498Hz.Is it possible to get the audyssey to do only the bass?
Anyone know if any other Denon or Marantz receivers have similar enough components that they may also rate well in Amir’s tests? Like the Denon 4500h, Marantz SR7013, Marantz SR6014??
Curious what are you basing this opinion on?Looking at the top Marantz processor reviews, the Marantz AVRs shouldnt score as high as the x3600. But the Denon x4500, x6500 and x8500 should be able to score even higher.
Yes, we need more of themAren’t measurements wonderful
- Rich
That would be far too logical! Haha. We've seen failures in much more pricey pieces with higher end components than the X3600. It seems more about implementation (architecture if you will) than simply a sum of the parts. It would be really cool to see how a "500 series" Denon piece measures compared to the X3600.Its all speculation until Amir tests the units but from x3600 as you go higher in the Denon range you get bigger power supply, better DAC and better processing. Once you reach x8500, you have assignable amps on all the channels with the option to turn them off as well as 8 of their highest model DAC for every 2 channels. Implementations is the key but in theory it should perform the best out of all the AVRs tested.
Seems Denon got something "right" with this one, especially on the digital side which is where so many AVRs and Processors fall on their face. For $1,100 and ability to full utilize at least two channels of a high quality external amplification for the LR channels I'm not sure I see the need to spend more for the 2018 series AVRs. I am anxious to see what the X4600 and X6600 AVRs look like when they are introduced (when ever that may be).
I think it’s been mentioned before although I own the Denon X4200 and run it with 9.1 assignment. (Setting on pre out to fronts). Guessing it should behave similar to the X3600. I’m using separate pre amps on all channels. (Monoblocks and stereo amp)
It sounds good with music and movies and I can’t tell any difference than maybe better from my Onkyo 5509 pre pro.
Overall happy but it would be interesting to see measurements on the unit. Maybe someone will send it in. (I live in Sweden).
I need a new AV pre seen onkyo 5509 cheap spec wise its plenty for me however hdmi failures a concern.
