Would love to hear your opinion on this latest Audyssey XT32. Is it still worse than Dirac?
Cheap denons are awesome! Got 4300 used couple of years ago for $500, inside and outside looks exactly the same as this thing. Same power, same 11 preouts, 2 subs, I would guess 90% same internals, Xt32 with app, same low res UI.. They are mass producing these, I doubt they design them from the ground up. I would also advise looking into last year's comparable model which is going to be 2/3 the price and (just guessing here) perform comparably.
Did it get hot while measuring? Mine gets hot even when running just stereo preouts and 2 subs, but it never showed any signs of strain in subjective performance.
Actually, the x3500 was measured not so long ago, with disappointing results. So Denon must have done a reingeneering on this one.
Sensitivity (for maximum power) [V] 0.29
Dynamics [dB] 104
Signal/noise ratio (A-weighted filter, for 1W) [dB] 82
In AVR's like this, is it possible to disconnect power to the amplifier section to reduce power consumption and operate them as pre-processors?
I believe all of the current 11 channel processors can do this for the L/R channels. I don’t think the other channels can be disconnected however (someone correct me if I am wrong). The only exception is the X8500 which can disconnect/reassign all any channel and also run the entire unit in “preamp” mode which disconnects all channels.In AVR's like this, is it possible to disconnect power to the amplifier section to reduce power consumption and operate them as pre-processors?
The Denon X8500 does this. You can disconnect or reassign any amp.
Edit: I don’t know if it actually turns the amps off to lower consumption or not on the disconnected amps.
Thanks brother. I meant more like - is there a simple cable that can be disconnected internally to power down the amplifier module while still being able to use the pre-pro functionality?I believe all of the current 11 channel processors can do this for the L/R channels. I don’t think the other channels can be disconnected however (someone correct me if I am wrong). The only exception is the X8500 which can disconnect/reassign all any channel and also run the entire unit in “preamp” mode which disconnects all channels.
Does anyone else find it incredible that the X3600 outperforms the Marantz 7705/8805 processors? And you get 7 channels of good amplification.
Dolly Parton?To wit, you can push it even harder if you allow higher distortion level or allow busts of power:
It did. It ran warm even before I tested the amps.Did it get hot while measuring? Mine gets hot even when running just stereo preouts and 2 subs, but it never showed any signs of strain in subjective performance.
Should be possible.In AVR's like this, is it possible to disconnect power to the amplifier section to reduce power consumption and operate them as pre-processors?
I can but Denon specs seem to be accurate so you could go by their multichannel numbers.Is it possible you can do a power sweep for 4 and 8 ohm for 4 channels?
This one seems like a good performer!
You guys.... Fiexed.Dolly Parton?
