Given the recent focus on the various Denon AVRs I figured I'd post my research and observations. As I had no need of 8K video and preferred not to be bitten by the multi-channel bug Amir found in the 3700 I recently picked up a 3600.
The thing is about 3/4 of an inch taller than my last AVR and the Denons are noted for running hot. I was already tight on space so cooling is a concern. I'd read elsewhere that when running on "Auto" for Eco mode that there is essentially a hard transition to "Eco Off" at about 45 on the volume scale. This seemed odd to me as I would have thought it was dependent on the source volume, but it does indeed to be the case. So on anything except a silent source with the volume above 45 you will hear a relay click and the receiver kick out of Eco. From my observation there would seem to be no downside to "Auto" as for anything but the softest listening it won't be used. It really does seem as if if was designed only to satisfy regulatory requirements for idle power draw.
While the unit does have two fans they never activate in normal use despite the unit getting quite warm to the touch. Amir isn't the only one who has noted this. Fortunately for me I reached into my large store of PC parts and had a spare Noctua 140mm fan. Noctua makes great stuff with a focus on durability and low noise. Problem was until recently you had to deal with tan and brown fans!
This particular fan starts and runs fine on 5V and I used a DVM to measure a maximum current draw of about 390mA. So I grabbed an old USB cable and wired the two together. I initially plugged it into the Denon AVR's front USB slot, but the bad news here is that the USB is powered when the unit is in standby. I thought I was stuck until I remembered my TV has 3 USB ports and the 1A one is switched with the TV. Problem solved! So when my TV is on I have the fan gently blowing across the top of the unit. The unit now only gets warm to the touch and I can't hear the fan at any seating position in the room. When you shut down the TV and AVR so does the fan!
For folks without the PC parts basket and the extra USB cable a variable speed USB fan is usually under $20US.
