Denon AVR-A1H
Recluse-Animator
https://www.denon.com/en-us/product/av-receivers/avr-a1h
9.4.6 ch
15 x 150w
8K
DIRAC upgradable
$6,500
Dougey_Jones
For $6,500 this needed to have balanced pre-outs for all channels and at least 2x XLR inputs. If rear panel real estate was the limiting factor I would've accepted a breakout dongle solution.
Recluse-Animator
Recluse-Animator
At this price DIRAC should be included.
Speaking of DIRAC this has 4 sub outputs and can adjust them individually. I find it hard to believe that it would make a noticeable difference as people have gotten great results with just 1 output and multiple subs. I haven't seen anyone test the difference between using 2 subs from 1 output and 2 subs from 2 outputs though so I could be wrong.
It's overpriced as you can get separates with stand alone DIRAC for the same price.
sarumbear
Finally there is competition to Trinnov. This offers almost (20 vs 15) the same number of channels as Altitude-16 & Amplitude-16 combo (which I have) and similar power (200 vs 150W). Trinnov set-up costs US$30,000. Even with the Dirac upgrade cost added, Denon is in a different league price wise. In fact it is a steal!
I also do not see XLR only on subs an issue. You are buying an integrated surround sound amplifier, the only output other than speakers are for subwoofers (which are almost always active) and they are balanced and there are four of them! What's the problem?
Recluse-Animator
Recluse-Animator
As I wrote it's overpriced and not a steal. You can get separates for the same price.
Trinnov is more expensive as it is a premium product with the best room correction money can buy.
Amplitude 16 is class D and the Denon is class AB.
Apmplitude 16 is also overpriced as you can get two 8ch Hypex amps with 250W @4ohm for 4400€.
sarumbear
I respectfully disagree.
What surround processor/amplifier has 15 channels which is cheaper?
abdo123
Brussels, Belgium
But that defintely doesn't have 15 channels of amplification. There are few more as well.
sarumbear
Thank you. Haven’t heard of that before. Are there any 3rd party reliable measurements for it that you know?
Sancus
We don't yet know what the "independent subwoofer outputs" mean either. This is important, even if DLBC is not included, if you can set individual PEQs for each channel, then you can optimize your bass with MSO without buying a miniDSP and *additionally* you can optimize the crossover for every single channel as well, which is not even possible with the 1 output -> miniDSP -> subs signal chain.
Dirac Live Bass Control is confirmed for the new lineup.
Well, also nobody knows when or if the HTP-1 will actually have stock again. The answer may be never lol. The date on the webpage is just a placeholder afaik.
sarumbear
Recluse-Animator
Recluse-Animator
It means that DIRAC calibrates all 4 sub outs independently. How much of an improvement if any it will have we'll have to wait and see.
People get great results with 2 or just 1 sub out using multiple subs with DIRAC.
Recluse-Animator
Recluse-Animator
That’s an amplifier. I asked for a processor with or without integrated amplifiers.
Just buy the cheapest AVR with the connections and formats you need and use it as a processor and buy a stand alone MiniDSP DIRAC.
abdo123
Brussels, Belgium
This is literally the most anyone would need in a modest Home Cinema, 250W is insane. That's enough to have 100dBSPL (anechoic) 4 meters away with a 90dB/W speaker.
sarumbear
I can only assume that you have not read any AVR/AVP reviews on ASR.
sarumbear
sarumbear
There are a lot of speakers with much less sensitivity though and people with larger rooms…
