Denon AVR-A1H High-end AVR Review
Rate this AVR:
    Votes: 9 3.0%
  • 1. Waste of money (piggy bank panther)
    Votes: 46 15.2%
    Votes: 171 56.4%
    Votes: 77 25.4%
I have asked before, for a TRUE explanation of why all in one AVRs tend to have mediocre numbers to okay or so at best.
In addition to welwynnick's rationale, it also depends on how you define mediocre? This is the AVR-A1H thread, and A1H is an AVR, the "numbers" are as good as the so called separates such as the more expensive AV10, AVM90, Trinnov Altitude 16, and quite a few "separate" preamp and power amps.
On all else being equal (but that's rarely the case) basis then of course the more separate the parts and components, the more likely noise could be reduced. The fact is, some AVRs tested on ASR did have better numbers than many separates also tested on ASR.
Is it the components all being in close proximity TO each other, or something additive when measuring from input to output of a combined unit such as an AVR.
I know they are not "shooting" for SOTA numbers, and most buyers are okay with just "good or okay" numbers.
But at the same time, doubt they (Engineers) say, "Hey lets make the numbers mediocre......??
For me it's dead easy: all room correction processing (Audyssey and Dirac) and Dolby/DTS/Auro3D) surround codecs with their bespoke (protected?) chips need (much?) longer signal paths and power supply leads compared to a pure stereo DAC hence the mediocre 'numbers'. But does this matter? I have Dirac ART running on my A1H and movies and music never sounded as punchy and detailed. The A1H is a true convenience music and movie powerhouse within a sane budget. And it comes with another bonus: my wife is able to operate it without any issue :cool:
One answer not hit on here is the fact that good engineering takes time and the desire to make things exceptional rather than "just good enough to work".
But we have come a long way baby. Going back to some AVR reviews done here 10 years ago, the general state of the AVR market wasn't great.
Once ASR and a few others started shining a light on some quick and dirty practices, some manufactures made the effort to improve the breed.
Getting SOTA measurements still takes extra cost, care and component purchases but even some of the inexpensive models are now offering greatly improved performance..
Correct if there is one, but why hasn't Denon come out with a kick-ass pre/pro instead of more and more of these same avrs with similar mediocre numbers.
You'd have to ask marketing but I'd guess since D&M are one and the same corporation, they figure they have it pretty well covered with the Marantz AVP's
The big market is AVRs, with AVP's only being of interest to a few enthusiasts.
If you were to take seperates (Power amp, Pre-amp, Processor) - and measure them as a combined unit, I have a feeling that the resulting SINAD figures would be very similar to that of one of the better AVR's.
Or vice versa, if you were to measure the SINAD of the power stage of an AVR alone, you might well find that it is competitive with standalone power amps.
Whenever you concatenate a stage in the chain, you pay a penalty.... noise and distortion acrue.
So seperates APPEAR superior simply by dint of being measured in isolation
It ain't apples and apples!
Having said that, seperates typically sell for double or triple the price, so there is a substantially higher budget available for improved engineering....however that is often allocated to higher margins rather than higher performance.
One of the interesting results to come out of a few of Amir's Denon AVR tests is where he measures line output performance with the power amps both off and on.
There can be a significant difference - using the power amps degrades the performance.
No, I can't remember which units, it will take some searching.
Another thing that degrades AVR performance is having an HDMI input connected (even if it's not being used for the test). This mainly applies to older units.
In his second review of the Denon AVR-X4700, Amir measured 76 dB SINAD with the amps turned on, and 98 dB with the amps off:
View attachment 549133 View attachment 549132
That is likely not an issue with the newer models as evidenced in the SR8015, SiNAD would still be down by a few dB with power amps connected but won’t likely drop to 76 dB. D+M has apparently make some changes to mitigate the pollution from the power amps when they clip badly.
There are advantages to optical transmission of signals - in terms of isolation from various types of electrically transferred noise.
Sadly the SPDIF/TOSLINK standard is dated and becomes a severe limiting factor in our current multichannel high bandwidth environment.
But yeah whenever your connect components with a traditional metal wire - you also carry the noise along with the signal - often becoming a limiting factor.
Fully ballanced connections can mitigate certain types of noise, but not all of them.
Proper design of the receiving end can filter out much if not all of that noise if it is designed well.... and that is one of the advantages of digital signals - but the shared signal earth frequently carries noise, and wherever the component design does not handle that kind of noise well - we get degradation.
Would have been nice to see at least 7 channel testing, since Denon has become ridiculous with their claims. I had the AVC-A1XVA (in USA AVR 5805 I believe) it was a huge beast that weighs 99 lbs despite using a toroidal transformer (and they are more effective hence weighing up to 50% less than an equivalent EI transformer. It was rated at 10x170 watts and of course still with only 2 channels, but with the massive transformer plus little over 132.000 microfarad capacitor, it was much more likely to deliver the rated power than these "beasts" from Denon today. I remember reading a German test/review (only one I could find with actual test) of the Avr-X8500ha and denon claims 13x150 watt on this only approx 50 lbs receiver (despite using EI transformer) with only about 66.000 microfarad capacitors, but with testing, as soon as going 5 channels or more, the watts fell dramatically. I as far as I remember it was even a 1% THD @1 kHz testing, so far from the claimed 0.05% THD @ 20-20.000 hz test. Technology has improved, but when still using class A/B design cutting weight in half while using less effective/heavier transformer and claiming more power is ridiculous. It's the small chips that has become better in for instance video board, and they weigh next to nothing plus the don't really get smaller, because they just use more up to date versions, that have same size and weight, but has more compute power. Just like a 10 year old Intel i7 cpu still about same size and weight as now, but the new one can make more and faster calculations.
I think you're right, but for real world music listening and movie watching, there is usually no need to have such ACD equal output rating as 2, 3 up to 5 channel output ratings that Denon and Marantz claimed guaranteed at least 70% anyway, because even if a 7.1.6 configuration may have to deal with moments where the contents may drive all 13 channels to peak simultaneously, it would be for brief/short durations that might last a second or two, and the likes of A10H, A1H, or even the midrange X4000H series Denon can handle those moments without issues. Those have higher output needs they could do well with external power amps and that's why AVR manufacturers provide multichannel pre outs. One can argue that Manufacturers have done the right thing not to force everyone to spend extras on the 70 to 90 lb "beast" AVRs. It is not only money, but in many cases, also space, and weight.
Toroidal transformers are lighter that EIs but only on all else being equal basis, with advance in technology, it is quite possible that Denon's latest custom designed EI transformer may not add much weight vs Toroids, and if they were to fit a equivalent Toroid in the A1H or A10H, they apparently would have issues with the size, geometry of the case, so they had to make compromise, that's my understanding from a few videos. Again, we really don't know if using EI in those most models resulted in weight gain, though I guess may be possible a little, 1-2 lbs, just may be.
I understand ownership pride for those who own the big and heavy "beasts", I had my fair share before but have been downsizing and become very fond of the smaller and lighter gear now.
I used to like my beast amps a lot, but since switching to the tiny class D stuff, I seem to enjoy music listening more. That little one in the picture is rated 350 W/500 W 8/4 ohms, and I don't miss the giant 250/400 W 8/4 ohm class AB amp at all. Hopefully D+M would switch their heavy AVRs such as the A1H, A10H, and Cinema 30 to class D and SMPS soon so we can save room, electricity costs, the environment and our backs Lol..
