You should avoid the reduced impedance setting on any AVR by all means. Don't use this option !
The "reduced" impedance setting is not really a "reduced" speaker impedance setting, because transistorized power amps have already a very low output impedance, which is not hampered in any ways by speaker impedance. The mentioned reduction will usually lower the rail-voltages of the power transistors, which in turn reduces the amperage flowing through the power amps and by Ohms law (U*I = wattage) will reduce the output of those channels "a lot". Almost all experts, reviewers and tests therefor will warn you about that mentioned reduction ("avoid it")...
You will get a somewhat reduced temperature scenario but much reduced channel output. Note: Those manufactures recommend this mostly because of CE temperature rules.
This might not say that much to You, but output power per channel will even be halfed (or even lower) because of those actions compared to that usual output for those speakers.
