Hi all, recently my, less than one-year-old, Denon 6800 is giving me problems. I’ve written a bit about my setup and it is in my avatar. I use it in a hybrid mode; 4 Atmos speakers I drive through the 6800’s internal amps and the rest is driven by the Marantz MM7025 and 7055. I use oké-ish cables and have set it up both with Audyssey as well as Dirac.
The problem I experience is the front right channel drops in output to almost ‘whisper’-level. Of course this is very noticeable while listening in stereo mode however also in surround mode. When it happened a few times, it always is solved by switching off and on the system again, I decided to take the MM 7025 out my cabinet and switch the RCA-inputs (L->R and the other way around) I did it ‘live’ and immediately the front right speaker picked up the level and the left dropped. So my conclusion; no MM 7025 issue and no speaker issue. Leaving the 6800 and the RCA, the last seaming not likely to be the culprit.
What I did then is doing stereo without Dirac and the same occurred. It is NOT completely switching off the channel but very much lowering the sound level. Again; switching off and on again solved the issue for a while.
If I remember correctly it all started after my most recent Dirac calibration after I installed the second sub. Hence the idea Dirac could be causing it but alas, not the solution. So before I put in its cardboard box again and take it a few hundred km’s to the shop I sourced it, and having to wait for it being reproduced and hopefully repaired, what suggestions do you have? Right now it’s of the power. I could probably factory reset is or is it likely to be ‘hardware-driven’? I already changed the way I drive the front channels from ‘pre-amp only’ to ‘pre-amp and speaker’. This didn’t solve it either. Oké, open to suggestions…
Edit: did start it up again. In stereo the right channel is going down and up again from itself. No stable sound level anymore.
