LeGratteOreilles
- Joined
- May 3, 2025
- Messages
- 2
- Likes
- 1
Hello,
I have a Denon AVC‑X4800H driving a Kanta Center, 2 Kanta 2 for L/R, and 2 Aria Evo X1 for surround.
I have a crossover at 60 Hz on the Aria and the Center, SVS SB‑5000 down to 40 Hz, and Kanta 2 at 40 Hz.
I have some doubts because I switched the amplifier to 4 ohm mode, and I’m not sure if that’s a good idea.
www.audioholics.com
My amplifier has gone into protection several times, even though I’m only at 70 dB at the listening position (3 m away, -20 dB main volume, and Audyssey Reference set the Kanta 2 and C to around -4.5 dB, Aria -2dB).
I believe the Kanta 2 dip to 2.97 ohms around 105 Hz, and the Aria Evo X1 down to 4.6 ohms around 100 Hz?
Am I at risk of damaging the tweeters of the speakers?
Also Audyssey told me the wiring of my Kanta was wrong and detected an issue with the phase. But I checked and it looks normal. Red on red black on black.
I’m considering buying a Purifi amp to put on the Denon pre-outs for the 3 Kanta speakers to avoid clipping.
But I’m not sure if the Denon can handle the Aria Evo X1. It’s the most expensive purchase I ever made and I’m afraid of damaging something.
Any advice would be greatly appreciated.
Setting the A/V Receiver Impedance Selector Switch
This article explores the purpose and function of the impedance switch found on some A/V receivers. Tradeoffs of following manufacturers recommended settings are also discussed. YouTube video inside.
