Denon AVC-A1HDA MK3 2011/12 Edition Review
What do you mean opamps exists only on front left and right ?
I meant that literally.
The older models, including the ex-flagship AVR-X8500H does not even have those "final stage/buffer" opamps at all for any channels (though I am sure there are good reasons, that it doesn't need that stage to help), the volume IC drives the power amps directly without the NJM8080 opamp in the end stage. They were added probably since the AVR-X3700H (see page 66 in the service manual) and SR6014, and I can confirm it is the same for the AVR-X4800H (page 23 if you have the SM) and the Cinema 40.
Anyway, if, that part of the signal path would look like the following:
You can see that they are there for the FL and FR only, not sure about the reason, and the AVR-X6800H is a different animal so likely different implementation in the final stage too.
If you want to see the schematics, try the following link, someone posted that hard to find source for manuals sometime ago:
You won't find the 4800 there I guess it is still a current model so.., I have it because I bought it. Again that part of the signal flow diagrams have not changed from the 3700/4700 to 3800/4800.
Below is a link to some of bugguyca's findings related to the dac, volume ic, switches and the opamps that drives the FL/FR preouts:
In the case of Marantz, since the SR6014, it gets even weirder, as even bigguyca didn't seem to know why Marantz would add that opamp behind the HDAMs that are already unity gain buffers:
All channels are equals on Denon AVRs (except the 4th sub output on the x6800h, which is handled by one TI5102A like the ones on x3800h/x4800h).
You have a post dac opamps on most implementations, except the cheapest ones which uses a dac which embedded voltage driven output stage.
Those diagrams from the video are blurry, but according to the label, the orange block seems to show the opamps NJM8080G that are part of the post dac filters, before going to the volume ICs. So those small blocks that look like opamps are not the final stage that you may be expecting. If you follow the schematics you will see the NJM8080G opamps are only used for the FL and FR as D+M has been for several years.
The older models, including the ex-flagship AVR-X8500H does not even have those "final stage/buffer" opamps at all for any channels, the volume IC drives the power amps directly. They were added probably since the AVR-X3700H (see page 66 in the service manual) and SR6014, and I can confirm it is the same for the AVR-X4800H (page 23 if you have the SM) and the Cinema 40.
You can see that they are there for the FL and FR only, not sure about the reason.
I don't understand where the discussion is going. Let me restate.
There is necessarily a volume control on each channel in an AVR. Currently it is done in analog domain after the dac output stage with a dedicated an analog volume control chip, and the measurements shows that we don't get the full performance of the dac chips. The volume control chip has a thd+n of 104db so that's what we see max on avr-a1h, when the chip could provide >120db.
And I think we will get a better Sinad if it was done in digital domain in the DAC chip as the ESS does it natively. That's how most high performing standalone DACs are done today.
Note: I think I hijacked the thread. Sorry about that.
I simply told you what I know based on info, that the DAC IC's outputs are limited to 2-2.2 V approx., from published info, other than that I don’t have anything else to add. now After your last post though, I want to note one point that the dac for the Denon avrs don’t have >120 dB SINAD except for the A1H and A10H, the X6800H has the ES9017, you can check the data-sheet yourself as I don’t remember the exact number, probably around 110 dB SINAD that is -110 dB THD+N, still better than the vol ic’s -107.95 dB though just barely, and the Cinema 40/AVR-X4800H has the PCM5102A, that has THD+N spec of about -93 dB.
Hi guys we have completely gone away from the what this thread is about...It's about the AVC-A1HDA & AVP-A1HDA Models please and a review based on those models only and or any information that can be shared with regards to those models in particular please from other members of community that currently use or had owned these particular models☝️.
Obviously it's great information but why not just create your own thread with regards to the above and let's stick to what this thread was originally created for.
Many thanks ☺️☝️...
Hi Yes been thinking about that ..and yes it's a huge beast and ways an absolute ton just like it's predecessor A1XVA !!!!...
In order to match it in 2025 would be A10H or A1..
Yes the MK3 was the very last model of the A1HDA..and as soon it was made available for sale earlier on this year I grabbed it I did not even barter with the gentleman it was immaculate and 100% complete with everything original box packaging remotes the lot as the original seller upgraded to the current A1H.
He showed me the original receipt from 2012 he paid £1.3K and sent it back to D&M or all the latest hardware & firmware mods to be done essentially getting a new amp . As this is a UK/EU model and I live in London myself .
I would absolutely entertain and love to see how the A1HDA would stack up to either the current A10H or A1H .
I've also given the amp a thorough clean up inside and out so its more or less spotless .
However yes it very risky and would cost quite alot of money and insurance to send it off .
I can't afford that risk and it's my dream amp ..sadly perhaps maybe another member that lives fairly close-ish next year maybe ..
Anyways we can only pray .
Thanks everyone.
I think the test of the amp section would be a little off since europe uses 50hz in the power outlet, and USA uses 60hz. So Amir would probably have to use a down converter. Plus coils run better with higher frequency. So an AVC-A1H testet for the north American market will probably have about 15% lower power output in Europe unless they beefed up the power supply for the European market, which they very very very rarely do, but still claim the same watts. Sometimes when looking under the specifications at the back of the manual, you'll see different numbers according to european, north American or Asian market. I know some Onkyos have that listed with lower output for European countries
