D
Deleted member 31910
Guest
You guys are sure a welcoming bunch, aren't you?
I was doing my best to share my experience. That is all.
Google is your friend.Don't know what this means.
Come on... If you know the forum, you know that we saw hundreds of first posts like this one before. Then you should know how folks here should react. So, long story short: unless you've done proper controlled listening, no one on ASR is interested by DAC listening impressions. That's about it.You guys are sure a welcoming bunch, aren't you?
How dare you speak in lieu of the whole membership?So, long story short: unless you've done proper controlled listening, no one on ASR is interested by DAC listening impressions. That's about it.
You need kind of a thick skin when participating here but it will pay off. The biggest thing to learn really is how to do proper blind testing, that takes a lot of effort and has a step learning curve. It will reward you with increased certainity of what matters to you and what doesn't, in terms of signal reproduction proper. And believe me, a lot of things can actually heard in DBT's, there will be surprises.I get it, I just don't think it's very welcoming. I'm clearly new here. I tried to go out of my way to preface my comments by stating my own inability to technically articulate what I was hearing and you decided to in turn go out of your way to mock me for it.
I didn't, unless "long story short" has a different meaning to you.How dare you speak in lieu of the whole membership?
"Fatigue" is such a variable though, on what does it depend? I can have fatiguing listening sessions on the same set-up I use day in day out. If I go out that day and buy a new DAC, will the new purchase have somehow "fixed" the fatigue? I'd doubt it.So what is it exactly that I am hearing that is giving me listening fatigue if differences are inaudible/barely audible?
I understand, I mean, I know I get fatigue easier and faster when I don't get good or enough sleep. I guess what I was specifically talking about when I said fatigue was headaches. Anecdotally/subjectively, I don't think this explains it for me though as I have no issues with headaches with the D50 on good/bad days with other speakers I own... but the pairing with other speakers does cause headaches 100% of the time during the time I was experimenting with the combo... switching to an older, less detailed, and in my subjective opinion "darker" dac in my Sony DVP-S9000ES solved the problem I was having, as did playing SACDs on the unit...so I sought to buy a different DAC and settled on the Ares II. I don't get headaches now unless I turn the volume up pretty high and even when listening at loud volumes it takes while... I can listen at normal listening levels for as long as I like with no headaches. I just have a hard time accepting that this is purely a result of psychology when I had no negative bias against the D50 and only had positive feelings toward it prior to getting the new speakers."Fatigue" is such a variable though, on what does it depend? I can have fatiguing listening sessions on the same set-up I use day in day out. If I go out that day and buy a new DAC, will the new purchase have somehow "fixed" the fatigue? I'd doubt it.
If you look at it objectively, unless there's something seriously broken there should be no such obvious/drastic difference.
I said that I have no idea what is actually happening other than it sounds better to me. I wasn't making any claims aside from reduced listening fatigue with my speakers. Anything outside of that I agreed was my subjective perception. The only thing I questioned was whether it can all be chalked up to psycho acoustics... maybe it can be... I have no idea. Doesn't change my experience.
Did you even read my initial post? It doesn't sound like it. I don't even know how to respond to this.However, instead of saying Topping D50 is better or worse, use words like the D50 sounded better to me. because obviously what sounds good to you might be a completely different experience for someone else.
however when you use terms like IS WORSE or IS BETTER without evidence then you're saying your own subjective experience is enough evidence to judge the product. and then you will have negative reactions.
I would definitely appreciate learning things that will further my understanding of audio and contribute to better system building. What I've assumed all along is that it was just a case of bad synergy between the JBL L7 and the D50, but I had more interest in making the L7 work than making the D50 work for obvious reasons. I think the synergy between the D50 and my other speakers are very nice!I think you should hang around a little more and learn from some of the more technical posters here, on ASR. There are many explanations possible for what you're feeling or hearing, including your amp, speakers, room or even the recordings you're listening to. There are ways to find out what you're hearing and why. The DAC is unlikely to be the cause, but it could be, and it can also be broken or mismatched with your other components. Rather than guessing, you could learn how to find such faults systematically. But if you're happy with your new DAC, then simply enjoy and don't worry what anybody thinks of your choice![]()
This is nit-picking, I'd say. I think it is very obvious what is fact (very very little) and what is opinion (the bulk remainder). Anything that doesn't come with a packed list of established facts is opinion.Look, this forum is about consumer awareness and evidence driven purchase.
it's completely okay to share and have your own personal experience, and no one should stop you from expressing it or tell you that your own experience is invalid.
......Come on... If you know the forum, you know that we saw hundreds of first posts like this one before. Then you should know how folks here should react. So, long story short: unless you've done proper controlled listening, no one on ASR is interested by DAC listening impressions. That's about it.
Welcome aboard!![]()
......The D50 was just too clear and transparent and gave me a headache in short order. Subjectively, it also sounded kind of flat even though it was extremely detailed. The main thing was I would get a headache after listening for a short period of time even when adjusting at different volume levels. ......
I get it, I just don't think it's very welcoming......
When I got the JBL L7 at first I was mostly listening to SACDs. It sounded wonderful to me. In an effort to move away from SACD and improve my redbook playback, I moved the D50 from another system and paired it with my L7. It was at that time that I noticed the change in sound which in my subjective opinion caused headaches after a short listening period compared to SACDs. I found the sound to be extremely detailed and "good" but I couldn't get around the headache issue even after multiple attempts on different days with significant adjustments to the volume. Because I have many more redbook cds than SACDs I reverted to using the internal DAC inside my DVP. The headaches went away almost immediately. Sure, this could all just be in my head. To my ears, and in my subjective opinion, the DVP was less detailed, darker, and not as transparent.. I still wanted the micro details and clarity that the D50 offered, so I sought to find a new DAC which led me to the Ares II. Yes, it's quite possible that the listening impressions and reviews of other users had greatly influenced my reception of the Ares II. I'm just happy that my headaches are gone and now I have 2 DACs that I can work with using different speakers to find the right synergy between components.Unless I have misunderstood , I am more interested in why you were happy with the DAC for a few years, changed speakers and then get fatigue/ headaches from the same DAC?
Logically, arent the speakers (or how you, the rest of the system, the room and speakers interact) likely to be the issue? If indeed the fatigue/ headache are caused by the listening which I think is what others have taken issue with.
