The answer is no. Even if you have perfect frequency response and directivity, stereo speakers have some limitations that mean you have some choices to make.
1. What is your ideal pattern width? Do you prefer wide or narrow dispersion, or maybe even Omni or dipole? None of these is considered fundamentally more correct than the others. Stereo reproduction just needs two speakers that allow the creation of a stereo image, but the "pinpoint" vs. "envelopment" question is up to the listener.
2. How much do you care about dynamics? This boils down to getting more or less sensitive speakers, maybe leading to horns. Are you willing to trade off anything for unclipped, high peaks?
3. How much do you care about distortion and clean bass? This may turn you away from smaller systems like the 8c, or not.
4. How much do you care about phase coherence? There are users here who swear no system without flat or nearly flat phase down to the bass region is really hi-fi. Do you agree?
5. How much spl is enough for you and how big of a room will you be in? This will tell you how big the speaker needs to be.
Well, there is one, it's the preference score associated with the familiar Spinorama / CEA 2034 measurements. You can see this ranking at spinorama.org. however, you'll notice that this ranking has nothing to say about the above questions. No single number can objectively rank all speakers for all listeners because some important factors can't be defined as more or less hi-fi or aren't scientifically established as important to most listeners. In the latter case that doesn't mean they don't matter, and won't matter to you, just that we don't have the evidence to say it definitely matters for all speakers.
So unfortunately I can't tell you it's that simple. Reaching a final endgame system will require you to make some choices.
