Dedicated System Router/patchbay?
klettermann
Coastal Connecticut
I’m just coming off a system rerouting project using an old Z-Systems digital router and accompanying remote. It was really the only thing I could find that did what I wanted without redoing my whole system. See below. Basically it can take any input and route to any output in any combination. The main limit is that it just does AES, s/pdif and TOSLINK (though that's fine for my needs). It's also massive overkill but I couldn't really find any modern equivalent aimed at ordinary audio systems. This got me wondering - why??
What I've got in mind is a simple 8×8 stereo digital router/patchbay with some mix of AES3, coax S/PDIF, Toslink, USB audio, and HDMI/eARC. Any input could be routed to any output, one source could feed multiple destinations, and complete routing setups could be stored as presets. Front-panel &/or remote operation, no annoying computer required. To be clear, I'm NOT talking about some master box with a DAC, streamer, preamp, DSP box, or network-audio system. Just a flexible digital interconnect/routing appliance.
It seems like this would be very useful for systems with multiple digital sources, DACs, DSP, measurement setups, recorders, TVs, etc. Yet this category seems to have disappeared if it ever really existed. in the first place. All we seem to have is crappy little selectors for HDMI or SPDIF or usb or whatever. So I'm curious. What do you do? Is there a broader need here or am I the only one? Would anyone here actually have a use for something like this? Cheers,
An interesting one!
I can't say I understand what you need to get done - or maybe why you do it the way you do, but given that all your source signals can be turned into optical with converters (which may have noise or ground loop advantages) could you not use an optical switch?
Here's an example of 4-way optical switch - I'm only trying to provoke a bit of thinking, not offering a neat fix!
An interesting one!
Fair question. There a few things behind all this that evolved over time:
  1. I've become addicted to messing around with REW and DSP room improvements. I'm ongoingly messing with it in one way or another.
  2. That eventually lead to a second MiniDSP box (the Flex) so I could fool around with some unorthodox speaker additions
  3. In turn, that lead to the problem of how to feed both DSP's at once. And being able to switch between DSP's is a necessary part of 2.
  4. At some point here I decided that it would be nice to record on the DAT (though honestly I probably never will, but still....)
  5. Using a USB interface (the Focusrite) to run REW to the MiniDSP's is a lot nicer than juggling around with the PC usb cable
  6. Using the z-systems remote makes it easy to route everything everywhere all at once in any combination. No cable work, no multiple switches, etc.
  7. Last and definitely least, for some reason I'm just biased against TOSLINK.
Hope that clarifies better even if some of it doesn't make much sense. :facepalm: Cheers,
Yes the Digital Detangler models look wonderful.
They cost thousands new, and were often custom-ordered for specific port counts per desired format
Now available cheap as chips secondhand - be grateful!
My Yamaha DME64N with 4x slots for @ 16ch AES/EBU, ADAT or analog add-on cards, same results, same topic domain. S/PDIF was a consumer gear format, AES much more common for pro use
Niche of a niche, those companies that technically "could" create such delights at low cost / high SQ would need to sell 1000x volume compared to what the actual demand is.
The professional target market has moved on to AoIP protocols all the routing is IP/port# based, not physical racks of expensive connectors.
USB is like Firewire, PCI / PCIe that = "PC interface" never see host mode, always a gadget that requires a host. Look for Class 2 compliance so no dependence on driver updates down the road. RPi compatibility...
Just as with DSP, its own topic domain, far beyond basic routing/format conversion.
ADAT is the lingua franca for connecting the two domains.
And BNC Word Clock for connecting multiple AD / DA units when expanding.
8-ports is just the entry point, small beer.
And don't get me started on HDMI "standards" best to stick to outboard extractor gadgets, easily swapped out as flavors change.
As for the back end wiring over distance, IMO convert as much as possible to audio over CATx (RJ-45 without ethernet)
Then why change? :)
