No, Im just aware of the pitfalls of sighted listening which is what you have based your decisions upon. I cant bring you an example right now of a DBT that shows difference between connections - but I'm not sure what that would demonstrate to you if I did. You could simply perform this comparison yourself if you had genuine interest in the result
The point here is
you are the one seeking to spend money on a new card because
you apparently want
"better clocks" - this is a
technical improvement, one which you believe will provide a corresponding
subjective improvement. However the
technical solution to that problem is to use a USB connection which would utilise the DACs internal clock. Yet you dont want this.
So if you want what you want, regardless of any other evidence or advice -
"More importantly it's the one I choose " - then yes it very much sounds like dogma. One has to shrug ones shoulders and walk away and leave you to it
